Hi Joe,
Your SHO forum friend brings out a point ....that has been the argument all the time for using DP plugs with EDIS!
I raised the same question with the Motorcraft engineer, and I'll try and explain his response. One thing to understand first, when a coil "discharges" (due to the induced field from the coil primary into the coil secondary), the voltage will only build up until the spark occurs, and will not increase any more. There are several parameters that effect the voltage required for the plug to spark. In addition to the gap, and pressure/composition of the cylinder charge, the physical structure of the plug electrodes also determine the spark voltage. A "blunt" electrode requires a higher voltage to spark, than a "sharp" electrode. With the "fine wire" center electrode being sharper than the platinum bead on the older DP plugs, the spark voltage is lower with the new "fine wire" platinum's. With this lower spark voltage, there is less energy, so electrode erosion is reduced. Because of this, platinum is not needed on the outer (GND) electrode. I'll keep an eye on mine to see how they do!!
I hope this answers the question on why only the center electrode is platinum on the new "fine wire" plugs. As explained by the Motorcraft engineer, there are several side benefits to the lower voltage:
1) lower misfires
2) longer coil pack life
3) longer plug wire life
These points alone are reasons NOT to increase the plug gap wider than the recommended gap. I have seen many posts about gapping plugs wider than the recommended gap!
I hope you have a good weekend Joe, and keep in touch!
Bob
