JBL sub-woofer repair
fkirk1
NC
If anyone is interested, there is a stereo speaker repair center in Charlotte NC (http://SpeakerDoctor.com) that will rebuild the original JBL sub-woofer in the SHO at a pretty resonable price as compaired to having to replace everything with different parts. I removed the speaker from the sub case & delivered it to the store & they charged me $15 parts & $15 labor. In my case they did a "Refoam" of the speaker & tested. It was affordable & easy for me.
fkirk1
NC
Just adjust the bass to max and the treble to minimum and boost the volumn to 50% or higher & you'll know if the sub-woofer is still good. If you don't get distortion or rattle you're probably still OK.
ShiftyShoMTX
Ohio
Mine was blown so I took it out and used 2 part epoxy to fix the foam were it had ripped. Prolly not the best way but it works until I can find a replacement.
Vazcular
You can buy a JL Audio 8w3 and it will fit perfect. I have one for sale right now with the stock JBL box and only used for less than one week.
FO-SHO
Philadelphia
When my stock woofer died I bought a 10''. You just have to widen the woofer box a bit and drop it in. The amp powers the bigger woofer fine and adds a considerable amount of bass compared to the stock setup without redoing the entire system.....
Vazcular
Didn't think a 10'' would fit. Could get a nice sounding 10'' and an aftermarket amp. Maybe I should have gone that route instead of my Kicker L7 Solobaric that blows itself out of the box when I turn it up.... Just knew the 8'' would fit so I went with that set up. I like how you still keep your trunk space.
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
I just cut a big enough hole for a 10" sub....then dropped it in. It needs some tuning (just grabbed an extra 10 I had lying around just to see if it would work)...but works and fits fine.
kevingotashotoo
200 or so ponies
peterborough,ON canada
do you have it sitting underneath the back window sill like stock, or do you have it showing between the two speaker with that 10", cause i had that idea dont know if it is a good one
SASHO91
Zoom Zoom
San Antonio,TX
yep the ten sounds really good for being in such a small box...
i would have had a ten in mine, but i cut the hole too big... :slap: :slap: :slap: dam i felt like a *******.... and i work with systems all the time.... :doh:
i wanted to run an 8''... as that would be a good balance between highs-lows.... as where the 10'' is only good for mids and highs... and on the occasion, a low or two...
really depends on the speaker though...
But yes the stock amp will power a 10'' enough for a nice sounding system... nothing over the top, but a nice overall balance...
TREpaNaTion
Local Metal SHO
Minnesota
finger nail polish holds for a little bit but cant withstand to much.
LeddZepp8687
The Keg Rider
Naperville, IL
I just pulled my stock one out today, it was blown and I didnt need the weight. And I got a neon STB to put in the back and the sub was in the way. id like to put a 10" in there someday..
