In 2-3 months will get new sway bars.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Can you elaborate ?? I was on my back and jack stands too !!!!!!! Do you have a video ? Just curious !! I tried every possible way and I couldn't snake the MOTHER FLOWER out !!
Are you referring to the insulator mounts? I just snaked it out through the driver side. No video unfortunately
joe raptor
Pt. St. Lucie, Florida
they're already installed , my mechanic had to drop the exhaust system and replace the sway bar with no problems, to bad I don't have a lift !!!!!!!
joe raptor
My mechanic show me how close is the second hole on the sway bar to the frame it is , so he used the first hole instead and still very tight on turns, I'm very happy with the results !!! :thumb::thumb::burnout::burnout:
FiveLeeter918
Tulsa, OK
Are you lowered? The test cars at the facility all cleared fine but were stock ride height. I still need to get some measurements done to get specifications for the adjustment end links so that us lowered cars can utilize the more aggressive hole, but given the tightness with even the first hole I'm not sure I could handle the second hole haha.
Ecoboost_xsport
Sacramento, CA
I know you already got it done, just wanted to show the video I made, in case it can help anyone else. Note how I removed the stock one from the vehicle. It's also an Explorer Sport, but it should uninstall/install similarly:
Autox4fun
Kalamazoo, MI
does anyone know the correct part # for the rear sway bar links ?? I heard you have to go longer than the stock one !!
I run a Flex, Megan coilovers and did have touch down issues, popped one side of my factory end link. 10mm stud, and roughly 6 inch is what I switched to. I sent pictures and measurements into Joel at customer service at Whiteline.
fordfanstan
CA
Could you post here what you used?
Just sho up
illinios
Planning commercial launch in April, but reach out to Joel at Whiteline to see if they have any more from the initial run.
Lee you are absolutely the man! It’s always been such a pleasure working with you. Thank you for all you bring to this community.
shootinirons
