Help starts and runs rough then dies
davekar
Pa
ok so i have a 89 sho 155,*** miles when i got it, it had spark issues turned out just to be missing bolts in the dis control modual.After that it started right up and had it running for about 40 mins and then i had to wait on the front and back glass from the junk yard they took like a moth and a half to pull the glass so i hadnt touched it since went to go and start it up the other day and nothing, jumped it and it started but really rough then died off, and continues to do so. replaced the fuel filter, same out come my machanic says says sounds like its outa time when started and firing order is correct heard it could be some control modual by underside of the radiator but also know that the fuel pump and cooling fans still turning on. please help out of ideas
davekar
Pa
already serched the fourm nothing really sounds close any other suggestions?
Siman
Location Location
bad gas? did you put any staybal in it or anything that will help the gas sit? might want to see what codes its poping. start it up and by hand keep the throttle open and run it for a little wile till you get the bad gas out of the line... if you let a car sit for a wile i know this becomes an issue...
davekar
Pa
no i put lucas aditive to the gas and 9 gallons of 93 high test already tried keeping it started by the throtle in the engine bay and it still dies off the car isnt staying on long enough to keep memory to pull any codes
jruss1601
Southwestern PA
well, i'm no expert at all but i'm been searching for answers for my car and this one sounds to me like a camshaft (people say it causes the cars to run rough) or maybe the DIS module is loose or not connected properly. I've read it needs to have an electrical glue backing..... or it may be out of wack
Well i better stop there. I just figured some ideas are better than no ideas
davekar
Pa
ok so i decided to replace the spark plugs i only changed the front 3 so far and its running a bit better but still dying off im going to change the back three and then change the cam sensor and see what that does the dis modual was what was wrong in the first place it was missing the bottom two bolts when i got it but about the eledctronic glue i dont know but thanks anyways if anybody has any other suggestions let me know btw the car wont hold memory for me to be pull codes because i cant get it started for long enough so thats out
davekar
Pa
ok so i changed the back three spark plugs and now the car stays running at idle but when you hit the throttle it dies again any opnions
lowc
aka vapah lock
Quincy, massachusettes
check ur tps and iac. ive never used any type of electrical glue and have never heard of having to use it although dielectric greese in the connectors wont hurt
jonheese
Used-To-Know-It-All
Fogelsville, PA
If you start replacing parts without running the codes first, you're most likely just throwing money away. I'll never understand why people ignore the targeted diagnostic system built right into the car...
It's like a doctor randomly prescribing medicine and procedures, hoping they fix the problem, without ever asking the patient what hurts...
davekar
Pa
what is the targeted diagnostic system that is in the car
lowc
aka vapah lock
its the on board diagnostic system or obd it tells ur pcm if there is an issue with something in the operating system odds are you dont have a scaner. so if a may suguest you find someone that has one that is willing to show you how to go about the prosess or find a mechanic. you should check out the PA clubs and talk to some of the guys in ur area, from post i have read the guys around there are pretty sharp when it comes to these motors and like john said ur gonna just keep wasting money by throughing parts at it and if i sound like a dic i apolagise just tryin to help
jonheese
Used-To-Know-It-All
Fogelsville, PA
Just click the link I posted above for all of the details on the targeted diagnostic system. All you need to do it is a paper clip and a brain. :biggrin:
