quikSHOilver
Yamahaized
Hey SHO peeps,
I am desperately in need of help to figure out the no start. I installed new walbro fuel pump and took f-22 raptor's advice by doing the FP test procedure . I did measure the voltage on IRCM pin 5 N' 10 which BOTH net 8.0v that goes same for fuel interia switch. Done that while grounded the FP from ecc test connector. I checked for the spark also from dis coil, found it gave out good blueish sparks. I have tried every menthods, from checking the timing belt whether it lined up, which it does, to spraying start fluid in TB to no avail!
One thing I noticed was that the fuel pressure was stronger when I grounded the FP terminal on ecc test connector rather than just key on alone, what gives? bad ground? where? etc ugh! Hope u guys out there can help me sort it out. Thanks...
Paul H
89' titanum
93' silver ATX
82' stang GT
88' stang GT
71' mach 1
Paul H
89' titanum
93' silver ATX
82' stang GT
88' stang GT
71' mach 1
