91grnPlus
Hi all,
New here (well kinda!). I remember when SHOforum just began...who was the founder...if I recall he was a guy from NY...sorry, don't recall his name, but he had a green GenII.
Back in '00 I had a red '91 Plus I sold...had it for about 2 yrs.
This week just picked up a green Plus at auction. It needs some major TLC!
So I've been trying to get the thing to crank over for the last day. I got it to crank 3 turns last night and that was it. Here is what I'm dealing with.
The PO relocated the battery to the trunk b/c they put in a remote oil filter...canister deal..in the area of where the battery should be!
I confirmed today that when the battery is hooked up in the trunk I am getting 12V+ at enf of the positive battery cable. Once I put it back on the started solonoid/relay I lose a ton of voltage...and it fluctuates from like 2-3V!! If I watch my underhood light I see the light get dim and bright and dim etc....then out of nowhere the light is full bright! I check and I have 12V!! So I open the drivers door and have interior lights and the door chime. Turn the key to "run" and have dash lights. If I turn the key off/on off/on things stay constant. If I turn to "run" w/o my foot on the clutch a couple more lights on the dash light up and the "coolant" light in the center of the cluster comes on. As soon as I run the clutch in to try to crank it everything dies!! I don't even get a crank. And there is no rhyme or reason when it will come back on. Sometimes if I open or close the hood I get the hood light to come back on but I'll go over and open the door and I'll lose everything!!
I'm stumped!!
Is there any way I can fool the computer so I can just try to get it cranked over? I even tried putting a battery on the fender apron and running 12V right to the relay...and that didn't change anything.
Thanks for the thoughts!
Mike
I'm stumped!!
Mike
