Cranksensor
Bringetto
What broke now?
Cali USA
I hate this damn thing..
Ive been trying to post here for a while but the aproval thing took awhile..
Sorry, anyways, i found the crank sensor was bad cuz the crank seal leaked oil onto it. So i decided to replace it and in the process of removing ther sensor... what happened?? One of the damn screws broke off.. So, my current plan is to lower the whole engine and try to drill it out and basicly start over with a new screw. Anyone else have any better ideas??
Gad to be here finaly, my sho has been through a bit and some help with it now and then would make me happy :thumb:
shofan33
Slick Silver
Edison, NJ
What i do in my job when a screw breaks is weld on to of the broken screw and use a pair of vise-grips and twist it out. I never liked drill and tapping to much time. Try not to weld it to the block if you try it!
Mr Anonymous
Tire Wall
The oil pump is aluminum, and the screw is steel, and I wouldn't recommend welding down there...
Is the screw broken off flush, or is there a stub sticking out?
greenbeanmtx
King Skidmark
Waco Tx
I know this sounds stupid but i had the similar thing happen to me and i took a tiny nail and a dab of jbweld and put it on there and taped it in place overnight as such where it wouldnt move. The next morning the jbweld had dried and i slowly turned the nail and she came right out. Id be for trying soemthing like that with some epoxy or superglue before you start lowering the subframe. Its a worth a shot anyway. I may have just gotten lucky though.
Bringetto
What broke now?
Cali USA
FLUSH
it seems like the casing around the crank comes off but its stuck on something, like a plunger is what my dad says. ive been pulling bits and parts off just to get the damn thing out and im pulling off the cam gear now. and its on the total other side.
gbizzle27
Bradford, Pa
i found some Craftsman ez-out type things at Sears...I think they would take it out since the screw isn't that big, or in tight.
Bringetto
What broke now?
Cali USA
well trying to get that plate out, there its stuck with that "plunger" and ive taken off the alternator, cam gear, and alot of other parts.. I feel like kicking my own ass.
Mr Anonymous
Tire Wall
Ok, are you actually trying to remove the oil pump???
If so, well it's too late now, you're going to have to remove the oil pan in order to remove the pick-up tube, and get a couple gasket sets in order to reinstall everything.
Bringetto
What broke now?
Cali USA
I know it had gaskets behind it, im not sure if it is the oil pump... I do know there is a gasket behind it, is there anyplace with a beakdown of the motor so i know what im looking at? I thought this would have been faster than lowering the motor but i think im about to regret it...
The Dude
pardeeville
Get a 90 degree drill and go to town, this way you won't have to drop the engine. Same thing happened to me. I started a hole and used a small easy out.
Mr Anonymous
Tire Wall
Here is a picture of an oil pump:
A8 12
If this is what you've been trying to remove, then as I mentioned you've opened the barn door, and now you're going to have to remove the y-pipe, oil pan, and pick up tube, and replace all the related gaskets. Naturally you'll be able to extract the broken screw much easier once it's out, but it's not the preferred method as I think you've figured out.
Search around the forums for some of the various rod bearing replacement guides people have written, as they will cover most of what you'll need short of replacing the oil pump gaskets and getting it reinstalled properly. For that it would be best to have a Helms manual handy, or perhaps someone could scan those pages from the manual and post them for you.
Bringetto
What broke now?
Cali USA
A8 12
All i see is a red X, can you save the picture to your computer and upload it? On imageshack.us it is free, you cant see it linked from e-bay, thanks though
Mr Anonymous
Tire Wall
Gotta be something on your end, since everyone else seems to be seeing it fine, anyway, here you go:
Bringetto
What broke now?
Cali USA
Thats where my screw is stuck, so your saying that ive taken the longer route, well i guess its too late now
