Connector Help
ice111103
I found a mangled connector hanging but my bad CV boot. Its red and has 8 holes. Two of the holes aare plugged and it has 6 pins in it. I found the other half and it sits on top of the trans. I was wondering what this controls. The connector looks like it got caught in the axle so its time for a junk yard run. The car was starting and running with it disconnected. I will try to snap a pic later
AREA 91
PA SHO SHOP
Area 91
This is on a 90 SHO, correct? It may be a dummy plug that isn't needed.
SASHO91
Zoom Zoom
San Antonio,TX
I can't think of any red plug in that area.... *scratches head*
The only plugs that are not used are grey, IIRC.
firstgen89sho
former Slo_SHO
Lloydminster Sk, Canada
drivers or passengers side?
there are a few brown/red colored connectors in the engine compartment
as said, there is one above the transmission, that is one of 3 connectors that go from the body harness to the engine harness, I also beleive that there is one up by the wiper motor as well.
ice111103
Yes its on the 90.
It is define. red
Is it possible for ABS? My ABS isn't connected and the motor seems to be running fine.
