Connector identification
14TR
Pennsylvania
Plugging away on the SHO ranger. I have a chiltons manual and some other diagrams I downloaded online, but I’m not certain on these couple of connectors and obviously in this application, there’s nothing left to line them up against.
The pic where I’m holding the harness in my hand, I know the lower plug went to the AC I believe, but is the upper one I circled for the driver side (front side when transverse) O2?
Other pic also looks like an O2 plug, but the female version. I just simply can’t recall what was what and these were the only connections I didn’t label. Oddly, the round 4 pin from the one pic will plug into the round 4 pin from the other pic which is odd because I really don’t think they belong that way, but just happen o have they keying clocked in the same position. One of these must be for that bank O2 and the other I assume is something I no longer am using (airbag sensor, power steering sensor, etc)
If there’s a diagram somewhere that breaks down connectors that would be great, as I haven’t found it and can’t find anything similar in my manual.
Thanks fellas
SHOrod
Torrie Tuned
Cedar Rapids, IA
What year are the Ranger and the donor SHO harness? Many of the Ford service manuals on DVD have a connector pinout section that usually shows the connector face, pinout, and wire colors. I can take a look to see if I export such listings for these vehicles.
-Rod
14TR
Pennsylvania
-Rod
The sho is a 1994 atx. The wires I’m showing in pics are exclusively for the sho. None of the ranger wiring is present
Thanks!
SHOrod
Torrie Tuned
Cedar Rapids, IA
I have tried to attach the PDF with the connector faces for the 1994 Taurus. This is not SHO-specific though, so keep that in mind.
-Rod
  • 1994_Taurus_Connectors.pdf
hosbaldosho
