changing rod bearings in atx?????
bulldogs3d
new york
wondering if anyone out there has changed rod bearings in an atx. It looks like a tight fit to get the oil pan out without removing the y-pipe. any advice would help because my bolts in the exhaust maifold to y-pipe are going to snap and I don't have a tourch pb blaster did not work either.
RStalveyARFF
too many shos
Georgetown, MA
I believe you do have to remove the y-pipe. Torches are quite inexpensive at most chain stores, ~$30. MAPP gas will help burn a little hotter also.
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
Definitely need to remove the y-pipe and the starter to drop the pan.
You probably are going to have more than your share of fun getting the two pan nuts off the studs closest to the transmission. More importantly, getting them back on is even tougher. It is almost a blind removal and installation. I used a couple extensions and a knuckle/wobble adapter on my socket.
- Mike
bulldogs3d
new york
thanks alot guys just did'nt want to do extra work if I did'nt have to that oil pan looks like it has a slight chance to fit but not much I found a guy that will torch them bolts up for me so I can do the rest any other tips in changing rod bearing would be cool since I have never done it before
oxrox
Edmonton, Canada
I took the exhaust off to do the oil pan gasket. The bolts on the pan were fine, but I had the exhaust bolts cut off from the Y-pipe...it went down hill from there. I should have done the rod bearings then, but they will have to wait...
Ryan
95 ATX
85k
bulldogs3d
new york
I got my bolts off the y-pipe today with some heat so there will be no drilling tomarrow I will do the bearings thanks for the advice guys
Pillarian
SeanMC
How did you get the oilpan off without removing the Y-pipe? That would save me a huge hassle.
Thanks,
Pillarian
