Bought a 90 SHO
yaycandy
Aerospace Engineer
Hanover, PA
Some of those things like the prop valve may not be available new. I never checked aftermarket but I doubt those are available. I only had to replace one and I did it with a used unit.
pn E6DZ-2B547-A
Yea maybe ill just keep it, the nuts there at it on the brake line dont look bad. Its a good thing to have since slamming on the brakes puts most if not all of the force to the front. I like the idea of it so ill do my best to keep it installed.
You can't just remove it. That would probably allow way too much rear bias. Even more than the bias plugs to keep them constantly engaged. Which I would probably not recommend without upgraded fronts.
yaycandy
Aerospace Engineer
Hanover, PA
No i ment keep the original installed. I was keeping that installed in general, either old or new
yaycandy
Aerospace Engineer
Hanover, PA
Finished with the intake pipes. Not perfect but alot better. Sanded and wetsanded in many stages but i wasnt happy with the polish look so i painted them with high temp aluminum color. Wetsanded at high grit and buffed them, need to clean up the gasket areas a bit. Still have to do the valve covers and timing cover also.
618A6B29 D7E6 454D 8FDA DCF0A5D3ECA0 366ED7B5 60CF 441A 8BC7 45A701EB3E74 4B1EAD11 5D18 44F1 9227 67B85DE3BC5A
Irish Pride
Irish Inside
MusicCityUSA
The first pic is a stock intake with the gasket in place. When you put a new gasket on you'll see right away if it's ported or gasket matched. If you look into it and see very little casting marks it's probably been ported. If you don't see a metal lip showing on the inside of the gasket like the 2nd pic then it's been gasket matched.
2014 11 11 233143 1727913
2014 11 11 233034 2146773
Then, if it looks like this on the inside, it's been extrude honed. If your intake is extrude honed then you really hit a homerun with that car. Not many people are willing to spend the money for EH.
20190104 222659
yaycandy
Aerospace Engineer
Hanover, PA
Got my intake gasket and rubbers kit. Why is there 4 gaskets for the butterfly valves? I only remember removing 2
Irish Pride
Irish Inside
MusicCityUSA
When the air horns are still installed you would use all 4. With big bore butterflys you remove the air horns and then only use 2. Your air horns are in a box in one of those pics you posted.
yaycandy
Aerospace Engineer
Hanover, PA
Makes sense now, i was wondering why all the sets had 4 and i only seen 2.
yaycandy
Aerospace Engineer
Hanover, PA
Found a dead rat under the fuel rails between where the heads and middle of the block is. Not sure how to get it out, oh well
yaycandy
Aerospace Engineer
Hanover, PA
Back head that looks different from the front has a sticker on the valve cover. Front head is cleaner even on the side casting where it mounts to block. Rear looks same as block for dirtmatching.
126A8E75 51CB 40BE 90E8 1AC1BE8E1A46
yaycandy
Aerospace Engineer
Hanover, PA
No paint? Just clean up? Looks really nice
Its painted, vht sp995 cast aluminum paint. Its like brand new aluminum paint.
Thats the paint i used, i put brand name and number if anyone else wants to paint theirs like that. Looks good
shootinirons
