Bought a 90 SHO
yaycandy
Aerospace Engineer
Hanover, PA
Took some pics. Found a box of old intake parts in trunk. Box for the mufflers, not sure if there in the box or the stock ones are in the box. The car is quiet, so quiet that i dont even get it. Has front strutbar and hook lifts removed. A rod that links into holes on hood and rad support is used. Uh not sure on belt system, little rusty from sitting but you know...hard to see. Found sunroof shade in trunk, looks shot and missing carpet. And took what was left of bra on front off and man did it shine up. Pic of the engine bay is there. I forget what else i took pics of haha
34A29B27 B793 40B0 AC3F 2BF01B4E14AF 83D5079D 16E4 4FE4 883E 7DE5C93AB8E5 7E8E06A1 8203 4BC2 A9CA 3FA0EFB11ED8 7CF5E54D 9A40 406C 9F61 E9AE4C693C0A 54982A60 71AE 43F7 B10D 22C2E2091493 34B95F10 B12D 4E93 9E35 A0C00C5F581C B63DBE97 5E6B 4F86 82B1 04D21ADB4F0F 96936756 FE69 4793 8055 041AFB84977F 3835AEAA BF57 416E 8CFA 19D62A9C4FBA
They used to sell hood strut relocation kits to use with the front strut tower bar. The bar gets in the way of the oem hood strut location. Shosource may or may not have some.
yaycandy
Aerospace Engineer
Hanover, PA
I seen a kit but i didnt say if it relocated it because of the strutbar so i wasnt sure the exact reason of the kit. Is there a shosource rep on here? If not ill shoot an email
There is but I'm not sure who is exactly where regarding screen names. I know Loudsho92 used to be associated with them but I'm not sure who is who now. Could be the original hood struts otherwise they would likely be on the vehicle.
Irish Pride
Irish Inside
MusicCityUSA
You'll have to email Mike at SHOSource thru the website. He isn't really on here that much. He's moved more to Facebook. I message him several times a week right now. He or Ryan his son are pretty good at responding.
They do offer a hood strut relocation kit provided it has a stock steel hood on it. The kit they currently offer will not work on the plastic Plus hood. He's working on a Plus kit right now. I did a test fitting on my car and gave him instructions on what needed tweaking. I'm waiting for the revised version to arrive.
yaycandy
Aerospace Engineer
Hanover, PA
Tore intake off too clean. Im surprised how easy it was, usually on the fieros i go to take off the intake and snap all the bolts but thats gm lol
Intake looks cooler on the floor. Im half asleep but i think i can put it on backwards if i put the motor in a miata. That would look cool.
544E66F2 9A20 451A 93A8 CA0CD88D32D6 047B08D8 6908 4B31 8469 D8014FF99EB3 F3F28292 2948 4A15 BC0C 5C10DA0741CB 10BE3D1B B503 4397 8326 9B67641B6383
yaycandy
Aerospace Engineer
Hanover, PA
Gunna guess this has the big bore butterflies already? Hey less i gotta buy lol. Took it all apart, removing what is left of the clearcoat/paint on the intake and will sand and wet sand it in stages and clearcoat it again. Im good at making aluminum look like chrome just takes a long time, oh fun days ahead of me.
843A332A 598A 400D B469 FBEC8E18342B DBF3C096 E93F 49B3 833B D481A917880D
yaycandy
Aerospace Engineer
Hanover, PA
Body is pretty rust free but brakes are rusty. Any way to tell if this has a the bigger brakes put on so i buy the right set?
73E3987C D99E 406D A82F 2B82D5587C94 D776C578 1850 4625 B4A3 1F01694C9617
You have the original 15'' wheels on there so I would say no. Most upgrades require a minimum 16" slicer wheel and other setups require 17's. You'll know for sure once you go to change them parts!
sperold
Last to Know
Look for the "SN74" bracket on the front brakes which allows the larger rotor.
Luigisho is correct, not much chance of having large rotors with the basket weaves.
Irish Pride
Irish Inside
MusicCityUSA
Those are definitely stock rear brakes.
You can get new prebent brake lines from SHOnut. SHOSource also has them on their website and are drop shipped from SHOnut. I just finished replacing all the hard lines on my 91+.
20200329 165610 20200329 165547 20200329 165655
yaycandy
Aerospace Engineer
Hanover, PA
Still havent found why the brakes leak. May of been a slow leak from sitting for awhile. Ill fill it up and see if i can find it leaking somewhere. Brake lines along the body look really good, just rust at the nut ends on about everything. And i hope bleeding the brakes with the abs isnt as much of a pain as it is with most 90s gm.
Nomospm
