Back to stock Motor Mounts
K-Dawg
Treasure Coast, FL
Has anybody had new, stock motor mounts last without falling apart quickly? Right now I've got SHONUT's Extreme mounts, but even with Gen 3 subframe bushings, its too loud and annoying for me. I've been thinking of going to back to stock unmodified mounts. RockAuto appears to have the rear mount for $40, so I might try that first and see if it makes a difference.
Phoenix
SHOHOLIC
QC , Canada
Whats so loud and annoying? Mines are almost welded + Gen3 bushings , and besides the ultra quick throttle response , I didnt see any harsness what so ever....
K-Dawg
Treasure Coast, FL
My car is my daily driver and the noise and vibration has gotten old. I don't want to have to deal with it if I don't have to.
95azSHO
phx,az
Give a holler to TYSHO he might have some GEN3 mounts. I got my GEN2's for my DD from him and they are great.
1993MTXSHO
Its a Taurus...
Jersey
I would think they would last a while if your car isn't ridiculously modified, and as long as you don't beat the ever living crap out of it. I think a big reason mounts fail is the fact that they get old and have been through a lot of hot cold cycles which deteriorates the rubber/material holding it on. So if you can find brand new stock mounts I think that would help a lot. However instead of the extreme mounts why don't you go with just a reinforced mount? The extreme mounts are seriously compressed, and the rubber starts to feel solid at that point, the reinforced mounts aren't as bad.
Or you could give these a shot:
http://www.bonnefinstudios.com/kwb/automotive/tech/mounts.htm
K-Dawg
Treasure Coast, FL
Thanks, I hadn't thought about the regular SHONut reinforced mounts. I may do that for the front mount.
yamahaSHO
E85 whore
Arkansas
Haha... I got to that point years ago and bought a separate car to solve the problem!
93rev2sev
Hockeytown
Also remember that you are working with a chassis that was designed 25 years ago...for use with 205 65 15 tires and mushy suspension.
You might not be able to improve the NVH by much.
Brett
SHOs before HOs
Minnesnowta
Let me know what you do with those reinforced mounts! taxes are coming! :sun:
92sho16
b00sted
Liverpool, NY
I have this style mm, very stiff. The urethane kenny used i think was the shore hardness of 94a, thats what i used. Its damn near solid, and is more than likely stiffer than the shonut mounts.
shospeed
austin tx
sims simple enought ! :woo-hoo:
Rockledge
Pluggin' away
Connecticut
Unless the stock engine mount has been improved over the years, I have to think that a reinforced mount is your best bet.
I have Gen III subframe bushings with SHONUT reinforced mounts (w/Eibachs and Tokicos) and I find the ride to be quite acceptable. And I'm somewhat picky. For example, I replaced some aluminum subframe bushings I had on there with the Gen IIIs because I thought the ride was too harsh.
Cocoa,Florida
ive ran a stock rear mount with a solid front for a while with no issues.noise and vibration are much less than with both mounts being solid.
