ABS issue
DoubleA03
Texas
I have a 99 with an ABS issue.
The ABS light comes on only when the car is driven.
If the car is started and idleing the ABS light will not turn on.
I have no speedometer issues, and the ABS light doesn't blink.
Any feedback would be appreciated.
jmpSHO2nd
Massachusetts
Check for ABS codes and let us know. Probably a bad speed sensor or ABS module. We can help you better with a code. A lot of cars won't set an ABS light while idling, most set codes while driven because the speed sensors help detect problems withing the ABS system.
Good luck getting ABS codes. That's a high dollar code checker you need for that.
My guess is the ABS module is getting funky. But I would take off the connector and spray it all down with some cleaner/****.
