'93 3.2 replacement for '90 3.0 ????
gkpettigrew
Gibsonville, NC
Could someone tell me if I can replace my '90 3.0 MTX (stuck) with a '93-'94 3.2 from an automatic car? The only spare engine that I have is a 3.2 out of a 1993 ATX car. I have the correct PCM for the car. I would appreciate any help and suggestions from members with this type experience.
Thanks for such a great site for a new SHO owner!:wave:
johndallara
Chapel Hill, NC
engine swap
I know this swap is possible with minor modifications. try the search service of the forum.
One approach I believe is to swap the 3.2 bottom up through the lower intake, and use the 3.0 upper intake and sensors, etc. from the recipient car.
Best of luck,
JD:salute:
Denny
Taurus Homeland
Atlanta, GA
Or no need to open the heads. Cut off a small section of the front head to accomodate the alternator, swap over timing belt tensioner, accessories, oilpan and motor mount locations and you're good to go. Drill and tap a hole to mount the coilpack or retain 3.2 plug wires.
Great for torque, especially of the low end type. :thumb:
