13:1 Compression 3.3L cam'n its ass off
zach44102
BIG TURBO
Georgia
Small little update. Got around to plumbing the whole brake system. Full ABS delete. Used a GL master/booster and lines. Lots cleaner and got rid of the huge ABS pump.
Also got the subframe in with new wheel bearings/hubs, control arms, and with koni/intrax.
Abs lines on left, non abs on the right.
A5C0 34EC60708D87 442 000000BA2C24A054 zpsb14d3c49
89E2 83DED9B7F59D 442 000000BA31F81915 zps045c2e69
867E DB5E5B84138D 442 000000BA371F158D zps461e32fd
96C2 2990970BD2A7 442 000000BA3D150811 zps3727d930
B91A C8D9CFD604D7 442 000000BA42F27AD4 zps514337c2
Relocated the ccrm
B0A8 7D3383F735EC 442 000000BA2347E249 zps3316be3f
zach44102
BIG TURBO
Georgia
No overspray at all, besides for the front windshield. But it will come off pretty easy. But tge whole windsheild might come out anyway
jayro
Auburn, In
I'm really hoping this build will produce a low 13/high 12 sec SHO.
However, I am gonna laugh my A$$ off if after all this work it still only runs about a 13.5.:laugh_ti:
It's only funny cause it's not me. If I was the one putting all the effort into it and got crappy results I would be ******.:madflame:
Sho Amo
SmkTyresntDrugs
Olney, Md
I have never seen anyone break an axle with the 3rd gen subframe. I'm not saying he won't though. I think the trans will continue to give him problems though.
96blackSHO
Wrentham, MA
i know personally i have destroyed more axles then i can count (gen 3 mtx with v6 mtx axles)
zach44102
BIG TURBO
Georgia
I wont see axles being such a huge factor. The car will weigh somewhere around 2500 pounds. The gen3 subframe does help a lot but i plan on using some nice big tires on the front and im pretty confident i will be able to crack down 1.8 60ft times.
As far as goals are
I want a 1.7-1.8 60ft, traps around 112-115 and a mid 12 second ET. From what i have seen so far it will happen. Maybe not the first run off the trailer but eventually after i get the car dialed in correctly i see a mid 12 second car.
96blackSHO
Wrentham, MA
As far as goals are
that would be very impressive
Sho Amo
SmkTyresntDrugs
Olney, Md
I was running 2.0 60ft times and even a 1.9 with drag radials and probably over 350whp. I'd like to see how you were launching.
