SHO_DOODmorrris
Owner & Fanatic
Correct me if im wrong, LOUD tapping at 2500-3000 rpm with no load... Am i ne need of some new bearings? i think so... 89 with 29X *** km's let me know please.
Sorry for the hijack, but to anyone that has done the RBs, how long does it typically take? I've never been in the bottom of a motor, but I'm fairly good as a shadetree mechanic.
Guessing by looking at the writeup on shophoenixproject, I was guessing 5 hours or so.
was the y pipe ever off ???? spray the bolts a couple of days before you do the bearings
I usually takes me 6-8 hrs to do the rod bearings with no problems with the y-pipe.......
( its one job I never rush doing )
seal the oil pan and let it sit over night for the silicone dry before I add oil
P
My dilema is, I have to drive there (to Pensacola from east Texas), replace the bearings, and drive it back, and I only have 2 days to do so. It's gonna be a great day :woohoo:
__________________
Mike Yeager
98 Ford Taurus SHO - Stock
01 Buick Regal GSX - Modified
00 Pontiac Grand Prix GTP - Modified - DD
99 Nissan Maxima SE - Modified - Wifes DD
95 Chevrolet Corvette - LT1 - M6 - Stock
Owner as of 1-1-08
Northgate Transmissions
Another point of view: Then I would not bother with the extra step of Plastigage measuring the old bearing clearance. Just put the new ones in and be done with it. The primary purpose of plastigage is to verify bearing to crank journal clearance when the crank has been reworked by a machine shop. It is impossible for your crank to have worn down enough on its own to require an oversize bearing, so the only viable option is to just put in the standard bearings and go. If you see abnormal wear on the crank journals, then that's a whole different ballgame.
