Ever since replacing the shocks the car has had a pretty good vibration over 60mph, where you can feel it coming on bad. I saw when i replaced the rear shocks that one of the toe links had a torn joint boot and was collapsed over to the side. So i replaced it today with a moog one from Rockauto. I just matched the length the best i could.
Factory toe link was really bad, very loose for a ball joint. Torn and also was bent down. Not sure if the oem ones are kinked down but the moog one was straight. Non pp so no recalls on the toe links.
Well after driving it a bit. Vibration is still there. This is on the side that the rear shock blew and the rear tire is cupped. After looking at the tire more closely while doing the toe link I figured it would still shake and its the screwed up tire. I just didnt want the toe link to break while driving. But at least i watch nascar and seen how the professionals drive at high speed crab walking after bumping the wall.
So i need a new tire and that should fix that. Like its really bad, even worse with a good shock that is holding it down to the road. With the blown shock it didnt vibrate much because the tires just flopped around the way it wanted t. To make it seem like a balanced tire. Theres like 20 high spots on the center of the tread and like 20 flat spots on the inner tread.
Nothing else looked wore out under the rear anymore so ill change the tire here soon and go from there. Also it shakes my brake pads out of alignment lol. But hopefully its not as bad now with a new toe link for the meanwhile.
