NoSlo
SHO Owner
If it starts when giving some gas pedal, after cranking alone isn't successful for several seconds, I'd consider the idle air controller as a place to start. Instead of replacement, you can take it off, and soak both ports with carb cleaner. A sticky valve will cause the intermittent low idle also reported.
