1992 ford taurus sho will not start
Bryan
What do you get when a deer & SHO cross at 45mph?
Morgantown PA
Those old parts are brittle and weren't that durable 20 years ago. Don't overtorque anything there (like pulley/tensioners and their brackets) because broken sheared off fasteners with crappy angles and no room to maneuver sucks!! BTDT in the front timing area and the back valve covers.
Careful with the timing cover plastic and it is not 1 piece there are overlaps when you go to remove it.
Hey thanks for the heads up! I will take my time and will make sure not to over torque anything.
Bryan
Morgantown PA
Questions about timing belt, cam and crank sprockets. Can I just put the new stuff on the way the came off or do I have to line the marks back up again? I mean won't the car know where the correct timing is? I thought that was the job of the sensors and computer. It's not like this is some old car that doesn't have that stuff.
zoomlater
Seattle, WA
All the marks have to line up again, if you didn't move anything, in theory it goes back on the same way. Look at the post below, there are links on what has to line up
Bryan
Morgantown PA
Okay so a small problem while removing the crank pulley. The bolt for my puller snapped off while pulling it off. Thankfully the pulled was off enough I was able to get a gear puller on it to pull it off the rest of the way. However the bolt that remains in the dampener. Will this effect it much? 6CFBA03B 62E5 4510 B9BF 8803746ACE9A
B933CD0A E61A 4E8B 9209 429339A7A481
I can see enough of a stub sticking out the back end I am going to try and attempt to weld a nut on to it and extract it. Already tried with some vise grips and there isn’t enough to grab a hold of, and the position is somewhat awkward and doesn’t let you turn with it anyway. Thoughts?
FastCAD
Miami, Florida
Okay so a small problem while removing the crank pulley. The bolt for my puller snapped off while pulling it off. Thankfully the pulled was off enough I was able to get a gear puller on it to pull it off the rest of the way. However the bolt that remains in the dampener. Will this effect it much? View attachment 85030
John Wyss [email protected]
Welding isn't a terrible idea. Sometimes pounding a tight socket on it can work or else drill a pilot hole and bolt extractor
Bryan
Morgantown PA
Okay I guess I’ll give it a try. I don’t have any extractors on me at the time.
Bryan
Morgantown PA
Original crank sensor out of car. This was how I found it. Also acorns where down with a whole bunch of other junk by the sensor. Will have to do a lot of cleaning before I put stuff back. Lastly the plastic cover covering the timing belt and stuff. Some of the seals on the bottom the lower plastic cover are a bit cracked. Does this really matter?
C609CEA3 ADC8 4C3B BC52 816D400FE6D6
DCFA4AE0 1893 41DE 8019 284EADB66F54
Bryan
Morgantown PA
Sea puller in action!
0EA224CD 3B4C 4504 A0C0 21DAD02B75BF
The right tool for the right job.0498903F AF0F 41FC 8750 2782977C7B23
Bryan
Morgantown PA
Okay so upon inspecting the cam sensor housing it looks beautiful and squeaky clean inside. Not a speck of contamination anywhere. So I am just going to skip on trying to dig that seal out of there and just replace the sensor. 30D18EE2 BDF1 436C BE5B EACD4FE2FBE1
B54CF5D7 BF7E 449F 9D2D F243BFC7B3A0
1C02B496 8294 42D4 B133 84DD63C316BC
Looks good right?
That's cleaner than any cam sensor area that I've ever looked at. Acorns and whatnot makes me wonder about all the crazy stuff popping off. Looking good. The cover is just that keeps debris away. You should be fine. I wonder if mothballs will keep squirrels out.
Bryan
Morgantown PA
It seems the crap like acorns and stuff is crap that fell into the lifter valley under the intake. Gonna try to stick a vacuum in there suck that crap out. Cam seals and main seal upon inspection were pretty hard and a little brittle, but I guess thats just from age.
zoomlater
Seattle, WA
Yep. Just do your best to get the timing belt right so you don't have to go back in. In fact I would run it with the wheel off and make sure it isn't sputtering. The problem is if it's like 1 tooth off you might not notice it until you have it on the ground and are noticeably down on power.
Bryan
Morgantown PA
I did turn the engine at the crank until the timing marks lined up. Hopefully its good. Just gonna take off the water pump then get stuff cleaned up. Will work more tomorrow.
Bryan
Morgantown PA
One last update. water pump now off. What a mess… you know I drained the radiator, but damned if the water pump doesn’t hide a crap ton more of antifreeze. Also a question. Where does the last o-ring go? I see there is one stuck in the housing and one for the connection to the engine itself, but the last? Is this the right place for it?
C2D32BA7 A198 4F6E 8A0D A30327212957
Bryan
Morgantown PA
And the other rings go here right?
6E2B68D6 1DA5 4942 9422 2C071602AE00
1B627CA5 2D9D 4892 93E3 A2330DEAEE97
So that would mean two o- rings go into the house in the back. One in the housing itself and one on the crossover tube in the lifter valley.
Bryan
Morgantown PA
Just asking because the write up done by sho Phoenix is pretty vague on what goes where.
I don't see a definite answer on here but maybe some helpful tips anyway.
I haven't had the whole thing out of one in 20 yrs. I know the general steps but exactly that 3rd gasket/seal not sure.
Looks correct. There is a seal at every junction I assume
dan.delargy
