Everyone just please remember, it was knocking WAAAAYYYY before I ever touched it!Please be @stripSHO !!!
You need to keep the bottles below 88 degrees. Above 87.8 degrees co2 becomes supercritical and the bottle pressure starts rising rapidly. Otherwise, look for a solenoid valve with a listed MOPD of at least 2000 psi. A "bigger" valve will probably worsen the situation, as it will increase the surface area that the co2 is applying pressure against and require even greater force to operate.I don't have a pressure gauge on my bottle. It is a big 20lb fountain beverage CO2 bottle. We do run regulators on them at the place I liberated my bottle from. Thinking about buying a pump and just transferring from big to small.
The solenoid on the car is pretty small, and I am agreeing that is it probably a volume issue with the big bottle. I have always run bottle gauges on my Nitrous bottles. However they have always been 10 lb bottles, and I have always used the big super power shot solenoids.
Probably going to start with a solenoid swap.
It's well documented. All is good.Everyone just please remember, it was knocking WAAAAYYYY before I ever touched it!
Well shit. So I should probably start looking at regulators also?You need to keep the bottles below 88 degrees. Above 87.8 degrees co2 becomes supercritical and the bottle pressure starts rising rapidly. Otherwise, look for a solenoid valve with a listed MOPD of at least 2000 psi. A "bigger" valve will probably worsen the situation, as it will increase the surface area that the co2 is applying pressure against and require even greater force to operate.
Most definitely. I didn’t realize you weren’t running one. No reason to struggle hitting it with full bottle pressure.Well shit. So I should probably start looking at regulators also?
I also didn't know about the properties of C02 and how rapid the bottle pressure can increase over 88 as @stripSHO stated. I know about nitrous, and I didn't realize how much different another gas would be. So I will purchase a regulator and go from there.Most definitely. I didn’t realize you weren’t running one. No reason to struggle hitting it with full bottle pressure.
It's been about a year (6k miles) since I did a 5 in and 5 out swap. I remember it being about $30 to 33 dollars a swap. My oil changes have gone up around $15 dollars as well.SM,
In my area the Mercron LV has always been about 9-10 dollars a QT.
Frank
I do and I get roughly 5 to 5.5 qts. I even verify on the stick after that my level is good. I did get 7 quarts one time. It was after my trans was replaced and I believe they overfilled my trans. I tend to believe that, because they serviced my PTU as well and it had 32 Oz of fluid it in. Should have roughly 18 to 20 Oz. I have it documented in this thread.Thank your Uncle Joe.
SM do you have your car on ramps when you do the drain of the transmission?
When I have mine on ramps I seem to get more like 6.5-7 qts.
I would take a copy of the alignment specifications with you. The SHO is kind of odd because the left and right do not mirror each other. Also request that they use reduced tolerances. There is a setting on most machines that will limit a "green" result to only half the factory tolerance. The final thing I would consider (purely preference) there is a different specification for the Police Interceptor. You may consider how you drive/the purpose of the SHO to you and if you prefer those settings. The SHO will be more for "comfort" as it was sold as a DD and the Police Interceptor will be more handling/performance as it is designed as a duty vehicle and with pursuit driving in mind.SHO Update: Gave the ole girl some love this weekend. Changed the oil and cleaned the catch can. As always there was some oil in the can. I did the 5 out and 5 in trans fluid swap. When the **** did MERCON LV become $10.99 a freakin quart? Used to be $6 a quart. WTF!!! Fluid looked clean so I was happy about that. I completely cleaned the K&N drop in and the air filter box. It was pretty dirty. Spent about 20 minus cleaning the engine bay looking at different items and making sure things were happy. Next oil change I will change the PTU fluid out with some Red Line LWSP.
While I was under the car I noticed some pretty bad wear on my drivers front tire. The inside edge was pretty smoked. I went to Discount Tire and they checked. That tire had 34k miles on it. So they prorated me another DWS 06+ and it will get mounted on Wednesday. I will probably take it the Lincoln dealership and get it aligned. All in all the SHO is running and looking great.
Thank you for the information. I will probably tell them to put it into the PI spec because with the H&R's it isn't the softest ride lol.I would take a copy of the alignment specifications with you. The SHO is kind of odd because the left and right do not mirror each other. Also request that they use reduced tolerances. There is a setting on most machines that will limit a "green" result to only half the factory tolerance. The final thing I would consider (purely preference) there is a different specification for the Police Interceptor. You may consider how you drive/the purpose of the SHO to you and if you prefer those settings. The SHO will be more for "comfort" as it was sold as a DD and the Police Interceptor will be more handling/performance as it is designed as a duty vehicle and with pursuit driving in mind.
I’ve had the reverse happen. When I just have the front elevated, I get ~5.5-6. Last time I also put the ass end up on stands to do something else while it was draining and got about 7-7.5 out. Must’ve been the sloshing around.Thank your Uncle Joe.
Thank you for the information. I told the Lincoln Dealership to put it into the PI spec and they did. It was really noticeable right off the bat. It turns in faster in IMO. Going on a road trip to Kommiefornia on Thursday so I will get a pretty good run with the new spec.I would take a copy of the alignment specifications with you. The SHO is kind of odd because the left and right do not mirror each other. Also request that they use reduced tolerances. There is a setting on most machines that will limit a "green" result to only half the factory tolerance. The final thing I would consider (purely preference) there is a different specification for the Police Interceptor. You may consider how you drive/the purpose of the SHO to you and if you prefer those settings. The SHO will be more for "comfort" as it was sold as a DD and the Police Interceptor will be more handling/performance as it is designed as a duty vehicle and with pursuit driving in mind.
