The HP Tuners Misconception: Control vs Abstraction on the EcoBoost SHO
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Ok something crazy happened. I recently made an 802sho business page for the **** of it and I made some posts talking about this. Eric Brooks commented on my post saying, it wasn’t me it was my Protege. Then Johnny Powers chimed in…I’m the protege lol. Johnny said get with me and I’ll do other years?
What do you guys 13+ guys need? Anything specific? IMG 0556IMG 0554IMG 0553
Says he already did an update to 13-16? Is 17-19 different?
Or maybe try reaching out to Johnny directly
802SHO
Another thing in my OS you couldnt edit indicated engine torque tables, you could only edit inverse. Now it’s editable too! Johnny opened it up. That’s awesome. Crazy you guys were right….prior to this…HP for 10-12 was a dead end.
To be honest I’m glad I didn’t listen and ignored all of you and kept going in the direction I was. Bc where we’re at now is way better than where we were before even if we all offended each other at one point or another.
802SHO
You guys already know this but just adding this so it’s a point of reference for anyone finding this thread. This is straight from engineering.
IMG 0584
802SHO
This is getting better. I told Johnny this am I’m still waiting on the new map and 4 hours later…..IMG 0610IMG 0611IMG 0612
I didn’t expect direct contact with the Ford Engineer to be this fricken cool! Johnny sounds like he’d equally like to be in the stands watching the car going down the track. This man wants to know if it worked just as bad as I do.
802SHO
Here it is. Look at this limiter that was completely hidden…just chilling at 500nm 369 ft/lb.IMG 0617
Now look at the PCM cutting throttle to pin it at 369 lb/ft. lol IMG 0094
Rev9 set to 881 nm. 650 lb/ft limit. IMG 0618
Ryan left everything else the same except he put torque inverse back to stock. Indicated engine torque and inverse are stock. It’s a limit of 1.95 air actual and over 560 lb/ft.
Let’s see what wg spring can do. Hopefully the rain breaks for a few hours and I will get a log in. Of course now it’s raining. IMG 0613
