It begins
bostonzmc
Altoona Pennsylvania
Been really inactive recently tbh was giving up on the car but I’m all in now dropped the subframe today with engine and trans will be posting more often for feedback from you guys as of now the engine is getting a timing kit new valve cover gaskets turbo lines and possibly down pipes trans is getting full rebuild1E25A983 6A10 481E AB07 7C5E21AEB0B6
bostonzmc
How do you tell if your ptu has too much slop or if it’s still good to run I believe mine has been replaced as the aluminum is brighter than the rest of the powertrain also has markings in paint marker all over bulbs and nuts
Shaggy
Administrator
Been really inactive recently tbh was giving up on the car but I’m all in now dropped the subframe today with engine and trans will be posting more often for feedback from you guys as of now the engine is getting a timing kit new valve cover gaskets turbo lines and possibly down pipes trans is getting full rebuildView attachment 83773
Sweet! Going to be a fun(and expensive) build!
bostonzmc
Transmission is being rebuilt hopefully with raybestos clutches if I can find them not sure whats all happening to the engine for sure getting a timing kit and new head gaskets and thinking about getting turbo cores from 5 star tuning getting all the exhaust and down pipes cerakoted to hold heat it aswell as the intake manifold to keep it out
bostonzmc
Thinking about putting Manley h beam rods and pistons in from Ortiz performance anyone use these yet and will I have to get a xdi pump and injectors or can I stay with stock fueling system for now
Bighead Super T
Bighead Super T
PA
I have Manley rods and pistons going in mine shortly... better price and lead time than Corilo and my Corilo did not work out thought I believe it to be a bearing and machine shop issue.
bostonzmc
Guess it was a good time for an engine refresh caught her just in time
bostonzmc
Sadly Ortiz did not have the pistons ready to go but they do have rods coming soon and I can get je fsr pistons from real street performance anyone heard anything good about these pistons
bostonzmc
This is my first build what are the pros and cons of going with a lower compression piston I really wanna get this thing put together but I wanna make sure I’m using the right parts
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
higher compression = better thermal efficiency
lower compression = better knock protecting and more timing.
A lot of turbocharged engines are knock limited on pump gas, which means as you advance ignition timing, you get knock before you hit MBT. That's one reason why e85 (or E30-E50 in our case) can make so much more power on a turbocharged engine, you can hit MBT or get very close to it on an engine that's normally limited by knock.
Low static compression lowers peak cylinder pressure, so it lets you get closer to MBT at high boost. You can run high compression, high boost on pump gas, you'll just be so knock-limited that you won't be able to run much timing, thus low power and poor efficiency. Timing is what makes so much more power. Most OTS tunes may add a bit more boost, but real kick comes from running more aggressive timing. The ticket these days is running a high compression turbo engine with e85 only, so you get quick spool and can still run aggressive timing. We find a lot of customer getting bent up on having low/moderate boost but higher timing, which other tuners are pushing crazy boost but low timing. Having a good balance leads to better fuel economy and power when you need it. Variable Cam Timing helps, but you can't overcome your
High compression, low boost is all about response and low rpm manners. This lets oems make a 4 cylinder with the torque curve near a 6's. Modern knock control has made this possible.
Back in the day, knock control was more of a damage control thing. If your knock algorithm kicked in, your engine was already getting f-ed, the algorithm just stopped the f-ing. Now, the systems are so responsive that timing can be adjusted on the fly to maximize power without risk to the engine. That's why many engines have a different power rating for different fuel grades.
DSport Magazine actually had a pretty good article on this about 7 years ago that is a good source of information when trying to decide whether to go high compression with less boost versus lower compression with more boost.
This is also a good calculator for determining your effective CR based on your static CR and boost/elevation inputs.
If you really want a good read, you can get into how Variable Valve Timing can further affect the Effective Compression Ratio of the Ecoboost Engine here:
While the Ecoboost engine still uses a standard Otto cycle combustion system, its VCT capabilities can allow it to also operate very similarly to the Atkinson model, which helps greatly to both make power and retain fuel economy.
FiveLeeter918
Tulsa, OK
Anyone currently running an sho on e85 seeming like that’s what I’m going to end up doing
there really is no performance benefit to E85. We've tested up to E70 on the factory injectors, but any more than that you need the XDI+50 injectors, and the only benefit is that you wouldn't have to mix at the pump.
The SHO reached MBT with E40-E50 timing, so really no need to run E85 given the added costs.
In our experience:
E30 - XDI-35 fuel pump
E50 - XDI-EVO + DW300C
E85 - XDI-EVO + DW300C + XDI+50 Injectors
yaycandy
Aerospace Engineer
Hanover, PA
E85 is never consistent in our area bud. I seen everywhere from 51-81 ethanol at pumps all throughout the state. One station to the next is too much of a difference even on the same day. We test all the time when filling up with e85 for my brothers flex fuel 1500. Easy part of the ready to go flexfuel gm is that it constantly adjusts for the Eblend in the tune. Its hard enough for me to get my sho E30…right at e30. Because of the constant variation in the Northeast states.
If there was an easy way, id run e85 in a heart beat. Currently looking into running e85 in my miata. Goal is to hit 350 crank hp with the 1.6l with 2560R currently at 290hp crank but that may pop her for good
yaycandy
Aerospace Engineer
Hanover, PA
Good to hear from you man we will have to meet up again once I get the build done think you could fab me up an intake or did you buy yours
I had it fabed up. I can contact my guy for you. Was around 3-400 for all pipes. Then extra for bov and 2 filters
Oh and intercooler lol
