Issue with tune
DrunkR0B0T
D.C.
Installed a tune from ortiz. Ran great. After I shut down the car and started it back up it seemed to run like it had when I mistakenly put the 3bar map sensor on with no tune. Struggling to push past 30 mph horribly shaking. Did the tune not stick, is that possible? Installed the tune on an sct x4.
tgabtg
Upland, CA
¯\_(ツ)_/¯
DrunkR0B0T
D.C.
yea ill check the connection and pins I think it is an issue with the learning software of the car. I don't think it is the sensor itself but the car fighting the sensor.
Thormx
Salt Lake
Did you replace the correct MAP Sensor?
DrunkR0B0T
D.C.
Yea I did all this correctly. Thanks tho. I'm going to contact ortiz.
DrunkR0B0T
D.C.
So i drained the capacitors in the PCM and it seemed to do the trick. Like i thought it was the computer still holding on to old setting that were making it flip out. Will update in a few days with progress for anyone else having this issue. Here is a link to what i did.
