ecoboost_xsport has a good point. Lets all calm down haa.
StripSHo has valid input that can/will be taken into account. I can add a simple 2:1 or 3:1 (whatever:1) reduction gearbox to the motor before the diff. It would require moving the motor up higher in the axle tube. I would say alter the differential ratio but I do not know of any company making ring or pinion gears for our platform. Some things to consider, the faster the motor spins, the more power it consumes... A lot more power. As well, the torque curve begins to fall after 3600rpms. The motor is rated to 8000rpm max but suggested to stay under 7200rpm. If I reduce it before the diff, here some numbers
>No reduction
-1200rpm, 692lb-ft, 29kw consumption, 26.5mph
-3600rpm, 692lb-ft, 59kw consumption, 79.6mph
-7200rpm, 392lb-ft, 101kw consumption, 159.2mph<- Would pull for a long time but not very hard
>2:1 reduction
-1200rpm, 1384lb-ft, 29kw consumption, 13.25mph
-3600rpm, 1384lb-ft, 59kw consumption, 39.8mph
-7200rpm, 784lb-ft, 101kw consumption, 79.6mph <--Pull medium to a semi high speed, must cut at 80mph
>3:1 reduction
-1200rpm, 2076lb-ft, 29kw consumption, 8.8mph
-3600rpm, 2076lb-ft, 59kw consumption, 26.5mph
-7200rpm, 1176lb-ft, 101kw consumption, 53.0mph <-- Pulls hard but has to shut off at 50mph or could over spin
>8.25:1 reduction (tesla model S)
-1200rpm, 5709lb-ft, 29kw consumption, 3.2mph
-3600rpm, 5709lb-ft, 59kw consumption, 9.64mph
-7200rpm, 3234lb-ft, 101kw consumption, 19.29mph <-- Impractical, essentially a tractor
The big thing to remember with gear reduction is you are going to consume more energy to rev higher and the higher it revs the less energy it outputs.
Performance sheet of the motor in the Voltage config close to what I plan is attached if you want ponder and play around with numbers.
