FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
I was just talking with my wife on getting the little one one of those electric cars for her to start practicing on! I wouldn't be mad if she ended up getting into racing.
My daughter is a daredevil. At 2 she takes her Lil Tykes push car and puts it at the top of our driveway and rides it down into the garage. I usually stop her but last weekend we got a new mattress so I sat it up as a backstop and let her drive into it.
Joshw0000
North Carolina
I've got videos of my girls (18 months apart) around ages 2-4 in one of those plastic cars with the push handle for the adult. They would take turns riding as I pushed them through the house as fast as I could popping wheelies and sliding corners. They would both cackle . At one point they got tired of taking turns so they both piled in. It's a one seater.
jman1200
Ontario
My wife used to give me the look every time I floored it, until the day I told her "why do I have a toy if I am not going to play with it" ... from that day on she just avoids the SHO :D
FREAK_SHO
Wisconsin
Best hope that doesn't turn into the back garage wall at 16.
Wsho
Sacramento California
I think I found my New engine just waiting for refund to go through from the other place. So here's what it says about the engine specs.
Little more than I wanted to spend but I think it might be worth it might as well go all out Balls to the wall..
Part Type: Re-manufactured Engine Assembly (High Durability) - Stronger than factory OEM equipment. 100% Made in USA.
Warranty: 5 Years / Unlimited Miles NO FAULT (One time free replacement no questions asked)
Installation Kit: Water Pump, Spark Plugs, Thermostat, Oil Filter, Air Filter, Premium Gasket Set & High Volume Oil Pump - INCLUDED
Shipping & Handling: Free
Availability: 1 In Stock
Unit Price: $5549.00
High Durability Features & Benefits
  • Engine blocks are magnafluxed, cylinders bored and precision honed, and main saddles line honed to exacting OE specifications
  • Camshaft bearing line bored for accurate center to center clearance
  • Engine blocks and cylinder heads precision surfaced to ensure proper sealing
  • Cylinder heads magnafluxed or dye checked and machined for three angle valve seats
  • Crankshafts are stress relieved, precision ground, and micro polished for optimum durability and surface finish
  • Camshafts precision ground or replaced with new to maintain the OE profile
  • Each engine is SIM tested for compression, oil pressure, oil leaks, unusual engine noise, and general operation condition before shipment
  • Engines ship with a finishing gasket set (oil pan, valve cover, intake etc.)
  • Return shipping on core included (for customers in the contiguous US only)
  • ISO 14000 & ISO 9001 Quality Control
Additional features of High Durability Engines:
  • The block is guaranteed to be a 1st time repair size machining (minimum bore)
  • Installation kit is included
  • 5 YEAR NFW (No Fault Warranty)
  • All new valve train; Camshaft, valves and Rockers.
  • Hypereutectic, skirt coated pistons
  • Hardened valve seats
  • Brass freeze plugs
  • No weld repairs
Joshw0000
North Carolina
  • No weld repairs
No fault warranty? They're proud of that motor. Better give her **** for 5 years.
COMpulse
Detroit Area
So, I'm almost done reinstalling the the radiator and new intercooler.
My 2 condenser bolts seem to go nowhere when I try to screw them in. Like, they don't bottom out in their holes, and they don't thread into anything. I don't see how anything could be out of alignment too far. The radiator supports are in their holes correctly.
Did I make a mistake by transferring the foam insulation from around the old intercooler to the new one? The inlet and outlet look like the same size and the new IC has the same brackets to hold the foam, so I expected the foam pieces would still fit. Getting the condenser back on was a very tight fit on the brackets of the IC,
I'm a little stumped, and stepping away from it for a few minutes. But I'm almost done. Could use some good advice here.
GotGrip?
Conversation Ruiner
Did you make sure the radiator was in the bottom all the way before you bolted it down?
Joshw0000
North Carolina
Wsho
Okay here's a question for all you gear heads that are rebuilding Engines. What can I do when rebuilding an engine to get more horsepower out of it? the guy at one shop can shave the heads or something for more compression? can you guys give me some ideas so what he can do..
Jordan_R
Missouri
Get rid of any rough castings with some porting
markmoomnu
