Livernois Tune
gerryh
Good to hear that you are pleasantly shocked by the tune! If you need anything or have any questions let me know!
I put my evenflo tstat in today and was just wondering if I did it right. I took the old one out, placed the new one it till it stoped, placed the rubber o ring around in front of tstat, reinstalled tstat housing, burped system oh and upgraded tune. Is that correct? Does the tstat go in any other way? Just curious. Want to make sure I did it right. Thanks
Jesus Luna
MinniSHO
Gerry how long did it take for you to get your tunes after receiving your tuner?
I'm new to this forum so apologize is this question has been answer.
I'll be racing next weekend and I'm hoping to get the tuner and tunes before Friday. High of 70° weather! Excited
Wallygator1
Hello everyone. Assume I know nothing about cars...because I don't. However, I own a 2013 SHO PP and am looking to make it faster without spending many thousands. Everything talked about on this thread seems to speak to that. I see things mentioned like 3 bar map and tune. I fear having some idiot work on my car and screwing it up. What do I do and who do I go to? Can Ford do this?
brucelinc
If you can register for this forum and post a question, you can load a tune into your car and install a 3 bar sensor! :) Livernois provides good instructions via email, video and phone. You should NOT have anyone else do that because there may be a time that you would need to revert back to stock and you need to know how it is done.
If you have never done any work on cars and lack tools, you could have someone else change the thermostat and spark plugs if they are needed. However, do not be intimidated by loading a tune and changing the sensor.
limited02
Olathe, KS
There are a few videos in YouTube that will show you what you need to know. Example:
Livernois Motorsports
SHOForumSponsor
Dearborn Heights, MI
Typical lead time is only 24-48 hours. You have nothing to worry about!
gerryh
When I received my tuner I had to get the 2 codes off my car . Then email LMS with the codes and any mods you may have done. Then they will email you a link so you can access tune with the MyCal and load them to it. You need windows based computer. Took like less than a day after I emailed them my codes and mods.
