BBS and ported intake runners
jonheese
Used-To-Know-It-All
Fogelsville, PA
I've already disassembled my intake once when I painted it & did my 60k. I have no idea what you are talking about... and what are "metal velocity stacks"??
Does anyone have pictures they can label for me? I know I"m making myself sound stupid but I don't care, I have no idea what you guys are talking about.
You can't see them at all from the outside, but when you disassemble the intake, when you take off the butterflies assembly from the surge tanks, you should see six little curved tubes (3 on each side) pointing into the tanks that look like this:
If you they aren't there, then someone already removed them.
Regards,
Jon Heese
FOMOCOTOSHO
I eat Rice.
Moorhead, MN
Regards,
Jon Heese
Thanks for the info & picture. That's perfect. Now I know what you are talking about.
So removing this well help allow the secondaries to open @ a lower RPM then? That's good right? :)
Phoenix
SHOHOLIC
QC , Canada
The only purpose to remove them is when you install BBBs. You wont improve anything if you remove them "for fun".
jonheese
Used-To-Know-It-All
Fogelsville, PA
No, you will not change the secondary-opening RPM at all. The secondaries open at a programmed RPM, totally independent of any feedback from the physical engine/intake. The only way to change the secondary-opening RPM is with a computer mod, like a TwEECer, LPM, etc.
Removing the horns is a good idea if you're installing BBBs, since the horns are smaller in diameter than the butterfly units themselves. In other words, if you install BBBs and leave the horns, you're not getting the full flow out of the butterflies, since the horns are relatively restrictive.
My point about the RPM tuning had to do with the optimum RPM that the secondaries are "tuned" for, which has to do with the physics of air moving in a column, nothing to do with EEC computer tuning.
http://en.wikipedia.org/wiki/Variable_length_intake_manifold
Regards,
Jon Heese
jonheese
Used-To-Know-It-All
Fogelsville, PA
Agreed. However, whether you remove the horns for a BBB install or not, you will change (lower) the points in the RPM band where the engine makes peak power and peak torque (possibly lowering the peak power and torque numbers themselves in the process). Not that anyone would want to do that, but it is what it is.
Regards,
Jon Heese
jedhead
westminster,ca
The ECU determines when the secondary butterflies open up. You can change the rpm for the butterflies to open via LPM or Tweecer. Mine opens at 3400rpm vs. 3950 stock.
Bob
jedhead
westminster,ca
Why so low? Just curious.
I think it makes the power transistion when the butterfiles open smoother. When the secondaries opened at 3950, torque came in with a bang and when powering out of the corner, pre-quaife days, it caused the inside front wheel to up in smoke.
Bob
formersho
Atlanta
Quite a few years ago this was a big topic. There was a fellow that dyno tested this theory. On a stock car it made 4hp on top, but it curiously lost about the same on the bottom end. I always remove them.
92MTX
Towley rules!!
Texas
I am keeping them, and drilling several 1/4 inch holes in them..
illSHOyou
Troy, MO
We deleted the secondary butterfly's in James (St. Louis SHO) car, but left the horns. I think he should chime in here with his opinion. Sure he has taken a hit on the bottom end, but he might be making more top end power than SHO's equiped with BBB. Becuase the intake horn is a good silencer that in itself is a indicator of a well working intake port. Take for exmaple a ported speaker. Say you have two ported speaker inclosures, one with a flared port and one with out. The flare port not only has less port noise, but increases the power of the said speaker by creating less turbalance.
Air likes to move in a pattern that raises it off the port floor and do a "S" bend into the intake horn. This is why many turbo intake manifolds have trumpets in the inside.
Bottom line with good hard data you could debate this both ways. James car has no bottom, but runs very good on top vs. highly modified SHO's.
Something to pick your brains about...
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
My car has good low end. I really didnt notice a huge loss by any means. It has the most unique sound. At the convention, you could hear my car over all the other ones out there. Its fast too.. lol
formersho
Atlanta
It will not hurt a stock SHO, we had a 93 ATX completely stock and I put a Cone filter on, and pulled the horns and it was a monster for being stock. They are just there to quiet the sound. The long runners do not have them and I think if they were an important part to how the intake works they would have them as well.
jonmon6691
No dough SHO
Wilsonville, Oregon
No. Intake runners are tuned to a very specific length to make peak torque at a specific rev point. The reason the SHO has long and short runners is so that it can peak in two places, therefore increasing driveability.
Take a look at this, its the intake manifold of an s62, the V8 from the BMW M5:
M5 intake stacks copy1
Those runners are NOT for noise reduction.
I've always been of the quiet opinion that the horns should be modified to work with the BBBs. It does not seem all that hard to do, but it would take some fabrication skills, including welding.
As far as I know, SHOBill is the only one that has done this. I'm surprised he hasn't commented in this thread.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
On my intake, I plan on removing the entire butterfly assembly, and then fabbing some new larger horns. I have two EH intakes, so I could dyno a stock intake, an EH/BBB intake with horna, then my monster no BB's/EH intake with big horns (in fact, I am right now laying claim to the name BIG HORN INTAKE!!!)
BlackonBlack89
burlington county,NJ
nova SS has some and they are very nice.
shobroooo
