BBS and ported intake runners
shotime1994
AirHammerAndrew
New York
Hi I have installed bbbs and ported runners should I leave the intake horns in or take them out? Thank you
shotime1994
AirHammerAndrew
New York
Will it make a difference if I use two gaskets and should I still torque the the nuts to 15ft lbs?
kikkinasphalt
Wrrrrrrrr
Missouri
No need for dual threads sir.
i tried searching for you. but little to no quality information can be had. most if not all of it was opinions.
IMO. they are a velocity stack. therefore are designed to help increase air flow.
but a lot of people say they are just in the way. i couldnt find any dyno proof either way as our search engine isnt very helpful on this subject (from the terms i tried)
AREA 91
Area 91
Only 1 gasket for the secondary butterfly's.
It's hard to get a torque wrench on all the nuts.
Too be safe, you can use a 1/4 inch drive wrachet.
AREA 91
Area 91
If you measure the "horn" you will see that it is smaller than the BBB you are installing.
shotime1994
AirHammerAndrew
New York
It seems to me that the secondaries are taking air from the back of the tank with the horns in. Without the horns it seems to me that the primaries will starve for air since the secondaries will create vacuum right next to them, is that correct.
whiteguy3
Scott MacIntire
Silver Spring, MD
No. Incorrect. One of the main reasons that the horns are in there are for noise reduction. And, if you think about it there is actually more room for the air to flow without them. With the horns in there there is a small centimeter gap between the horn and plenum wall that takes an almost 90 degree bend so you could argue both sides.
No horns. One gasket. ;)
Kens1992mtxSHO
The Commonwealth
This has been debated time and time again. The general consensus is to pull them for the exact reason stated above, they are smaller in diameter than the BBB's and with that logic will restrict air flow.
I pulled mine when I did my BBB install. Besides, it sounds more aggressive without the horns. :)
Kens1992mtxSHO
The Commonwealth
^^ What are you doing up at 4am??
The other reason for the horns is to act as a velocity stack, extending the length of the runners and drawing air into the secondaries. With BBB's the horns are not necessary as the consensus is that the smaller diameter of the horns will restrict air flow.
I could have sworn I posted in this thread already...
*EDIT* nevermind I see two threads were created.... why?
whiteguy3
Scott MacIntire
Silver Spring, MD
Literally nothing. I felt like a drunk who couldn't find his car keys. Freakin' high strung and my body said no sleep for you. There is two posts...I felt like it was deja vu too
zblackbeast
SHOtarded
Omaha, NE
IIRC on my green one i sold when i reassembled the intake i put the horns on backwards.. (facing the TB).. i could be wrong tho.. it was stock soo
FOMOCOTOSHO
I eat Rice.
Moorhead, MN
I'm looking at installing BBB's... but what the heck are intake horns? Anyone have a picture of what you are talking about? I feel stupid
LOUDSHO92
Rancho Cucamonga, CA
When you disassemble the intake you will see. They are sheet metal velocity stacks.
FOMOCOTOSHO
I eat Rice.
Moorhead, MN
I've already disassembled my intake once when I painted it & did my 60k. I have no idea what you are talking about... and what are "metal velocity stacks"??
Does anyone have pictures they can label for me? I know I"m making myself sound stupid but I don't care, I have no idea what you guys are talking about.
jonheese
Used-To-Know-It-All
Fogelsville, PA
I thought that the horns were there to lengthen the secondary tracts (for resonance tuning reasons), not for noise reduction (or at least not primarily for noise reduction)...
That is, the secondary runners are resonance tuned for a given RPM, and if you remove the horns (or change their length in any way), you change the overall length of the secondary intake path, thus changing the optimum "tuned" RPM where they function.
Granted, since they're smaller in diameter than the BBBs, clearly they must go, but just keep in mind that removing them results in a change of the intake secondary "tune". If I understand the theory correctly, this will tune the secondaries for a slightly lower RPM than factory... whatever that is.
Regards,
Jon Heese
