Mike Kopstain
Boost raises relative to throttle albeit slightly. I'm making 10lbs off of the line and 14 at the shift. Agreed that an older M90 is going to choke up top however. It's still going to make the boost but the air is going to be so hot that the knock at that RPM will negate any gains.SHO Dude said:So if you set the pulleys for 10psi, the same M-90 will pull like **** to about 4000 and then nose over just like it does in the GTP.
It does not. It ramps up (see above). The only time the blower would come down as it's being spun faster is if the belt was slipping. On cars with secondaries still on them I wouldn't be surprised to see a slight drop in boost when those open but the boost should still raise until redline, albeit it's going to be pretty hot at those speeds. Even with a cam that requires a vacuum canister we can still see the boost ramp up with RPM.This is a bit puzzling if you say that the boost goes down on the Grand Prix as the RPM gets higher. I would expect it to go the other way, especially considering that motor's poor inherent VE (pushrod, standard heads & cams).
This doesn't have to be the case. New toys like our suspension limiters help to keep the wheels on the ground. Transaxle components can be saved by lightening the rotating assembly. A lightweight flywheel, while not ideal for drag racing, helps to keep transmission "shock" to a minimum and should increase the amount of torque you can put through the transmission. Other things like lightening the car will also increase the amount of torque the car can take but most probably don't want to be riding around in a unibody with a seat.Now, two downfalls, out the hole power is delivered in smoke... That leads to two things. Burnt tires and dead trannies.
The power off the line (immense amount of torque) is going to make short work of the MTX-IV. An automatic transmission can be beefed up to deal with this, and a looser converter would reduce some of the drivetrain shock.
I'd be interested in seeing the long term affects of this setup on Tyler's car.
