Why does my key only work on the drivers door and ignition?
AllSHO_n_NoGO
Sarasota, FL
My SHO is my second 3rd gen Taurus. First was a 99 Duratec. Both cars the keys only work in the drivers door and the ignition. Neither the key worked in the passenger door or the trunk.
Not that its a big issue, just didnt know why. Maybe the lock cylinders are just frozen from not being used?
ThatShoGuy
michigan
idk if the key for mine works in the passenger side door but i know my dont work for the trunk, i figured there was a diff key for that ! mine is a 97
not sure why
shobote
Naperville, IL
Gen I SHO in my garage has 2 seperate keys; oine square for doors and ignition and one round for the trunk
SHO Continental
Moderator
Northridge, Cali
The trunks are typically a separate key, unless it's a wagon or fleet vehicle. FWIW, the doors may have been replaced and the key cylinders not changed out. I replaced the passenger door on my '93 without changing the lock, I have a remote and keyless entry so I hardly even need the lock on the drivers door.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
I'm pretty sure that the ignition key on the Gen 3's are supposed to open the trunk.
NebraskaSHO
Harumph!
Omaha
Mine does not open the drivers door but the passenger door. Try some powdered graphite on the key and try that.
stephen newberg
Ladysmith, BC, Canada
To get in a pun, the key is in the post just above. :)
The key will open the driver and passenger doors and the trunk if the locks are original and working properly. For a year or so, I think around 2002, the key stopped opening the passenger door and then a year later the trunk. Complete cleaning and lubrication of the locks and the key solved it and it again opened them all. If you keep up with that after you get it going, it will continue to do so. And while at it, clean and lub the antenna and it will keep working just fine too. :)
pax, smn
SeanMc
NoMoSHO
My G2, the key only works on the driver and ignition, but not the passenger, and I have a seperate one for the trunk. But I don't have a keyhole on the trunk :).
dan.delargy
