whole in my tranny
jeg
centralia, washington
well the other day i did a 3rd gear 100 mph pass on a piece of this honda and i hit fourth gear and it blew a huge whole in the back of my tranny where the shift cables , i'm guessing that the tourqe flexted the case so much i cracked resulting in a huge whole and loss of fluid. has this happend to anyone else, i have a nearly stock enginge with a k&n filter and a custom could air intake and i have subframe connectors so i don't know
<small>[ February 24, 2003, 01:14 AM: Message edited by: PROPHET ]</small>
RStalveyARFF
too many shos
Georgetown, MA
you just lost your diff pin. Search junkyards for a transmission, and buy a rebuild kit and video from shonutperformance.com
jeg
acually i did do alot of burn outs, so it's either my diff pin which i think it is cause i found it along side of the road after i felt it hit my floor boards, another possibility could be my spider gear, but either way a is a new tranny the best way to fix it cause i'm sure my gears have gotten hot
yamahaSHO
E85 whore
Arkansas
Yeah, your diff pin went out alright. That tranny is shot. Sorry to hear, invest in a Quaife.
Mr Anonymous
Tire Wall
A new (or more accurately, a replacement) tranny is the only way to fix it. That's the price of burnouts... Sorry. frown
jeg
yeah acually i believe it was worth i, to do the best burn outs you put fast food tray's under your rear tires and lock the e-brake on them it's like having rear wheel drive on ice, it's it possible to make my tranny stonger, i.e limited slip diff. or will that break just as easly
Mr Anonymous
Tire Wall
I can't imagine why someone would intentionally treat their poor car this way. shrug In any case, good luck to you!
nc89sho
S13 Sellout
Clemmons NC
if you don't put a quaife in with the new tranny, expect to do the same thing in a few months.
SHO--ripper
928 Euro
winsted,CT
These tranny's aren't that good for burnout's. I found out the hard way like you. :mad: O well i gots another SHO now and will have another very soon thumbs_u
Just for the record, that's a hole in your transaxle. If you don't learn from this premature destruction of your SHO, you might as well have another hole somewhere near your cranial matter. Burnouts are bad. You proved it.
Emerald94
Mississauga, Ontario, Canada
:D
:D
sdpatt:
jeg
hey burn outs are fun, what's the use of having a nice fast car when you don't use it your car can be fixed but a reputation of driving like a woman well enough said
Emerald94
Was that an insult?
You don't need a SHO to do burn outs. ****, I can do them with my lowly Civic.
I'd like to be a fly on the wall so I could see your facial expression when you get your tranny repair invoice from your mechanic. :D
jeg:
yamahaSHO
E85 whore
Arkansas
jeg:
Well, if you want a fast car you want to minimize burn outs. Its all about traction. Unless on the track trying to heat up the tires, burnouts are just for show. Sure you get a lot of people looking at you, but wait when you do that to your second tranny. Everybody will be laughing at you when you blow the diff again and you get smoke coming from the tranny.
bradman
Everett, WA
jeg:
Idiocy reigns supreme. :rolleyes:
haydenm315
Reisterstown, MD.
Yikes.... another one eh? I'm a little bit scared of this beings I don't have enough money for a new clutch, let alone a quaife and the necessary install parts, and other stuff that needs to get replaced when the tranny comes down. Is it just as bad to chirp second gear or is the occasional chirp ok? My assumption is that anything that goes from wheel slip to wheel grab is bad.
Groo
Glenview, IL
Bah, all these wet blankets are just trying to ruin your fun, Jeg. Buy yourself a rebuilt trans with a limited slip, and do burnouts without worry.
