You will need a press with at least 5,000 pounds of force. I had both of my front wheel bearings replaced at 240,000 miles. The shop had to subcontract out the work to have the old pressed out and the new pressed in because their press was only a 4,000 pres and coulcn't budge the bearings. I also had to replace of one of the hubs that had been gouged out from the worn out bearing.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
