Phoenix
SHOHOLIC
This weekend I finally got my SHO out after cutting the rear springs a bit , finished the exhaust (ditched the fart cans) , re-do all the brake hard lines and replaced a leaking fuel tank.
After 5 miles , it started knocking on top of the front valve cover , I stopped in an empty parking lot , opened the hood and I saw the front cam sprocket bolts were all loose (through the timing cover window I had made) and were holding by a couple threads....
WTF I did those with the impact gun .... but wait , I painted these.... They had loosened with the paint behind the bolts with the vibration (solid mounts).
So my wife convinced me to call a tow truck before the sprocket fails and destroys the valves and pistons (40+ cams) , I was ****** but it was the right decision. I was really afraid I had already damaged something with that knocking...
Fast foward today , I removed all the paint re-tight everything with lock-tite and started it , THANK GOD no more knocking. Phew.
