Well it almost cost me an engine , Close call...
Phoenix
SHOHOLIC
QC , Canada
This weekend I finally got my SHO out after cutting the rear springs a bit , finished the exhaust (ditched the fart cans) , re-do all the brake hard lines and replaced a leaking fuel tank.
After 5 miles , it started knocking on top of the front valve cover , I stopped in an empty parking lot , opened the hood and I saw the front cam sprocket bolts were all loose (through the timing cover window I had made) and were holding by a couple threads....
WTF I did those with the impact gun .... but wait , I painted these.... They had loosened with the paint behind the bolts with the vibration (solid mounts).
So my wife convinced me to call a tow truck before the sprocket fails and destroys the valves and pistons (40+ cams) , I was ****** but it was the right decision. I was really afraid I had already damaged something with that knocking...
Fast foward today , I removed all the paint re-tight everything with lock-tite and started it , THANK GOD no more knocking. Phew.
Phoenix
SHOHOLIC
QC , Canada
Yes , its a super cheap ass impact gun - dont get me wrong I didnt hold it like it was a wheel nut. Plus I re-checked with a ratchet.
38SHO
#1 Oil Abuser
North Palm Beach
I take it you've never been to a mechanic shop and seen people take off crank pulleys and cam sprockets before......
most professional mechanics laugh at torque wrenches.......
theres only two things I've ever torqued on my car
rod bearing caps
and valve cover bolts(more so just to have an even pressure applied and seal better)
yamahaSHO
E85 whore
Arkansas
They're only professional in the fact they get paid... not skill.
rod bearing caps
That's funny to see because the bolt has a collar (a stopping point where it cannot clamp any more). As long as they're tight and not stripped, it will ALWAYS have even pressure applied. That is a bolt where a torque wrench is NOT needed if you're any good with mechanics.
Phoenix
SHOHOLIC
QC , Canada
rod bearing caps
Bingo , for me its the intake bolts and rod/main caps.
The question is not what I used to tork it , the thing is that the paint loosened up behind the bolt and it did what it did.
Im not talking about a stripped bolt here.
Dont be such pansies guys. Geesh.
SASHO91
Zoom Zoom
San Antonio,TX
There are certain parts that require the use of a tq wrench... Cam sprockets? no thanks, tight is tight in that department.
My foreman would throw all of my tq. wrenches, ft. lb wrenches in the garbage if I used it on something silly like cam sprockets.
Not to mention most high grade impact guns have a varible tq setting. My 1/2'' IR has 4 settings and they are DAMN close! (checked with a tq. wrench).
I used my little 3/8'' butterfly impact to put my sprockets on. And that was back in Dec. IIRC.
I don't think I'd go THAT far. But I agree, the torque wrench CAN be overused.
I can't beleive you used an impact on cam sprocket bolts, though. Aren't those like m8x1.25...
yamahaSHO
E85 whore
Arkansas
You said you ran it in with an impact. If you didn't run it in all the way, then there was no relevence in this post.
Paint loosened up? With proper torque that paint shouldn't have an effect. Most piant would stick and take a set. If the paint were rolling off when you tightened it, it could effect torque reading...
I'm going to guess it was improperly torqued.
38SHO
#1 Oil Abuser
North Palm Beach
well if you don't have one down all the way it wouldn't seal right now would it? or if you crank on it too hard you might strip it...... thats why I put the torque wrench to it, to keep me from going too much on it
these are some of the smallest fasteners on our engine and I really don't want it to leak after I put it together..... this is why this is one of the bolts I torque..........
more importantly, the amount of torque a bolt can take is really about what material the bolt goes into, because its not the bolt that usually messes up.. its the threads of the head..... so when i think torque wrench and trying to do it right, I think aluminum heads... small bolt.... then I think how much of a pain it is to fix it once its stripped.... yeah I don't want to spend all day putting helicoils in my heads.... I'll take the torque wrench
I guess I'm just a horrible mechanic cause I put a torque wrench on a valve cover bolt on my own car...... let me go end myself because the almighty doesn't approve!
:woo-hoo:
seriously, talking about irrelevant posts, all of yours are on this thread
yamahaSHO
E85 whore
Arkansas
I know someone who didn't properly torque their cam sprockets and had a bolt break. It resulted in two melted and one cracked piston.
yamahaSHO
E85 whore
Arkansas
Like I said, if you're any good at what you're doing, you can't mistake the stopping point. Most of the people that I've seen strip this boltson this forum were using a torque wrench.
I guess I'm just a horrible mechanic cause I put a torque wrench on a valve cover bolt on my own car...... let me go end myself!
:woo-hoo:
Feel free to torque them, but I hope you're not doing it with a torque wrench that reads up to 150 ft-lbs. I run them down until they stop, then turne just a smidge more and they're done.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
Unless I remember incorrectly the stage 1 and +20s are not interference. Stage 2 and +40s make it interference.
yamahaSHO
E85 whore
Arkansas
That depends on what forged piston you get. Not all are created equal. But yes, with the Wiseco's I bought, I could run Stage II's and still not be an interference motor.
ManySHOs
South Jersey
+20's are interference. I proved it when I did the timing belt install a few weeks ago and rotated the pistons into a few valves.
I rarely use an impact to torque anything down unless it's a long bolt. I like to ensure that the bolt or nut is properly threaded - there's no feel with an impact and it's too easy to cross thread something or deform the fastener if it's small enough. Once I have most fasteners threaded part way, it's usually only a few more turns with the ratchet I was already using. Using an impact gun on cam sprocket bolts seems excessive. :)
Ian
