Spcymonkey
Okay, so here are the details of the car and the issue.
95 MTX 3.0 with 67k miles on it.
The car recently sat for about 2 years before my purchase of it, which may or may not be important. The gas in the tank is extremely old, but between the 1st and 2nd time this issue happened, I did manage to put a full tank of gas in the car.
Car recently had all the brakes replace. Metal brake lines, soft brake lines, calipers, rotors, brake pads, 4 brand new tires.
I was driving the car yesterday, and everything was perfect. All of a sudden, the check engine light comes on, and the car starts driving really rough. The car feels like it's misfiring, as when I give it a bit of gas, it jerks back and forward very violently, but it still goes. I pull over in a parking lot, and I let the car sit at idle. The car sounds like it's sputtering, but it doesn't stall, it just keeps sputtering around the idle speed.
I turn the car off, and wait about 2-3 minutes. I try to turn the car back on, and it won't start. It kicks over, very violently, but won't start. This goes on for another 2-3 attemps to start it. Finally, after waiting 10 minutes, I start it, and it starts. Now, the car idle speed is at about 1900 RPM!! However, I attempt to drive the car home, and the car seems to drive okay. Whenever I stop, the idle is still at 1900 RPM. The tachometer at first sat at 0for about 3-5 minutes during the drive home, and then somehow started working during the drive home. The check engine light was on the whole ride home.
I got the car home, and it sat overnight. I went to start the car today, everything starts up perfect, car idles fine, no check engine light, nothing. However, on a short test drive around the neighborhood, the exact same issue happens the exact same way, so it's def not a fluke incident.
This time, I was close to my local Ford Dealership (which has a special SHO mechanic on full time staff) so I dropped it off there. However, I'd like some input into as what some of the forum members think might be the problem?
The reason I ask is I just spent a decent amount of money on the hard brake line fix, and I want to get the 60k service done on the car, but I don't want to be putting a ton of money into the car if the issue is so serious that I'd be better off not fixing the car. Any feedback is appreciated. Thanks!
