Very Interesting Engine Issue
xshoel93x
SHO driver
Massachusetts
yessir back in the day they had those certifications. my stepdad currently has every certification ford has to offer, including those. oh and monkey if u replace or clean the IAC i would like to kno the result(yes i kno our problems are very different, just if theres a mafor difference, it sounds like u need an IAC too), my 93 really doesnt wanna stay running n stalls out as soon i put in gear, first maybe 10 times i try to go. i prolly look like a ra-tard for stalling an automatic
Spcymonkey
York, PA
We're going to replace the IAC as a precaution this weekend, and I'll let you know how it goes!
SHOclass
Conan has one
S. Windsor, Connecticut
I had the same exact issue with my 95' MTX and a very similar story. Check engine light came on ran real rough, bucking, but still able to drive. I pulled over shut it down tried to turn it over a few times until it finally started with my foot buried into the accelerator. The car started with check engine light still on. Now what happened next was the most annoying thing about the situation. My car ran like it was brand new !! ( mind you it had 183K on it at the time). I felt power in my car that I have never felt before while the check engine light was on. Anyways after I cleaned the intake and cleaned my Mass Air Flow sensor with M.A.F. cleaner (about 4 bucks) the problem never reaccured. Its like the engine just went into some sort of default mode, in which I understand is probably not good, but I had fun while it ran like a ***** ape
ycode90
Out in front!
Your computer is bad . I cannot believe no one else picked this up . These cars computers do not like to sit . I'd be willing to bet.
Spcymonkey
York, PA
It turns out was actually the MAF. The MAF was replaced and the engine now runs like a champion again!
ycode90
Out in front!
Well I geuss I was wrong. Mine did that same thing I replaced every sensor took it to 3 dealerships and several other shops searched this forum a million times after abuot 6 mos. I found a computer in a jy and the problem went away. Either way glad your fixed.
