Uh oh
Billm0066
Caliper Covers
USA
seems I'm not the only one who thinks our stock system is a bit lame. . .
Very lame. Especially the low end.
If you are running an aftermarket amp, is it absolutely necessary to run the power wire from the battery, or can you tap off somewhere in the back? I thought about adding a small amp and 10" sub at some point. Nothing more than 300-500 watts.
SHOrod
Torrie Tuned
Cedar Rapids, IA
It worked at low volume but when you turn it up where the power really starts the amp turns off because it isnt a good ground.
How did you determine that the amp turns off because of a poor ground? Where are you sourcing the power for the amp? Did you try adding a stiffening capacitor? What impedance is your subwoofer? Did you have the amplifier bridged?
It seems unlikely to me that the ground would be causing the issue....
-Rod
Blackwire1217
Florida
-Rod
Im using the same system that I put in my F150 (JL 500/1, 2/JL 10W3V3 4ohm) and I had the same symptoms with it when I first put it in and after making a solid ground it worked. The power is coming from the battery through a 4 gauge power wire and a 150amp JL fuse block. The reason its that big is because I also have and will install the mid/high setup I have (JL 300/4, 2 sets/JL XR570-CW)
way2evil
ny
Tweeters are mounted a bit low for proper imaging, ain't they? :bonk:
Yes you could say that, we angeled them up but it was the only spot on the door they could go. The top half of the door is some sort of foam and there is some stuff on the inside of the door that could not be moved.
No, you must run it from the battery.
Looks great! Did anyone consider upgrading the subs in the deck to keep there truck space?
Yes, but the stock "subs" are really just 6x9 speakers.
darreli
Run'n from BPD
Michigan
W2E...
Nice job! What components did you go with? I'm probably going to swap out all my speakers with JL Audio ZR or C5 components and add the stealthboc with the 13.5. I had that same setup in my Lightning and loved it. I wanted to go with some 10's or 12's in a fiberglass enclosure in the space right behind the seat but I'm trying to keep the weight down. Just out of curiosity....you didn't want to use the a-pillars for the tweeters?
way2evil
ny
W2E...
I went with JBL P660C components. I was going to use the stock location for the tweeters but we would have had to mount the crossover in the kick panel and it would have been a pain in the ass. I am going to change out the stock tweeters and center channel and hopefully wont have to amp them seeing how the stock amp is now not providing power to the 4 door speakers.
way2evil
ny
Yes surround still works although I never used it because it makes music sound horrible.
way2evil
ny
Ever pull them apart?
Blackwire1217
Florida
Meant did you ever pull the other side of the trunk apart looking for the amplifier?
Yes I pulled the other side apart and nothing is over there. It was raining here all day monday so I wasnt able to take apart everything to find it like I wanted to. But weather permitting, I will find it on saturday!
RedCandySHO
Canuck SHO 2
Orlando, FL
Raining? LOL! That was a Monsoon....
I am curious guys. I am not a thumping heavy bass in a car system, but notice the sound quality isn't that great. I don't really need more volume, just interested in making the system sound clearer. I know very little about car audio, so what would you suggest? Just a speaker replacement?
way2evil
ny
Just do speakers and then if you want some bass add a 12 inch sub. Music doesnt come alive unless there is a good amount of bass there. If you ever have the pleasure of sitting in a car with a good system in it listen for the difference.
