TimboSHO
Intermediate
Yes, I know there is a thread that already has this title, but I have different issues. I have a MarkVIII 80mm Maf, 3.2, stage 1 cams, and about every other bolt on. I have the right maf file loaded, changed the idle and the displacement in the scalers.
I can't get it to idle correctly. It idles at about 2500, then finally comes down to 1500 or so. If driving, the idle fluctuates after putting the clutch in, until you come to a stop (then it races again). I think I might try the stock Maf and stock x2j file again and start from scratch and see what happens.
Any other ideas? I've swapped the TPS and IAC just to make sure it wasn't a problem with them.
