Turbo Guy's: What kind of Boost Controller are you running?
somedude_001
Western NY
this is a good question, i'm looking for a boost controller as well. I think i'm looking for a electronic one though.
SASHO91
Zoom Zoom
San Antonio,TX
So your looking for an EBC? Or a MBC?
TurboXS has a nice line of MBC's. Buddy is running one on his GSX w/ a .50trim... :naughty:
Not sure on the EBC. I figured Apexi would be your best choice...and its probably like right down the blocl too.. :biggrin:
Toolman
Boost it!
Grand Lake, Oklahoma, USA
EBC's can do SOOO much for you. They are a lot more than just a way to increase your boost. Currently, I am using the Greddy Profec A. A google search will tell you all you need to know about it. I am jonesing for a Profec E or similar machine, as they allow you to set your boost curve vs RPM. That would be sweet!!
TT SHO PROJECT
OHIO
i use a "home made" bleeder valve... cost like 2-3 bucks.. works great... only down side to the bleeder type mbc's are that you Slightly increase the lag, ebc's block the boost from the wg till it hits a set psi then it opens as much as it needs to keep the turbo at the set psi.
just my 2 cents
-Turbo Bob
1slickRED89
Guest
Toledo Ohio
two stage MBC here. I think it was $15 on ebay, the voodoo II. I use the MBC as a second stage and the WG spring as the first stage with a manual valve to flip from one to the other. it was cheap and it works. also i have an ATX so it's always spooled, so it may be different for a MTX.
somedude_001
Western NY
+1 for turbo ATX's everywhere.
now where are those jackstands I need to replace my tranny again... just kidding.
i keep forgetting about that cory. I was looking for a EBC that would lower my boost for first gear and raise it after teh shift but I can do it your way for a lot less with a switch.
groove83
PimpTempoOwner
Kalamazoo, MI
jbeano said:
I got my mechanical one from this guy. No turbo lag and simple to install.
http://www.boostvalve.com/
HA, thats funny. I love the fact they take a Grainger valve that cost 7 bucks and marks it up to 40 bucks.
I will say though, the Grainger valve works GREAT. I had one on my Turbo Voyager, and the dodge guys have been using them for years with great results....
I will see if I can find the page that shows how to build it yourself.
Here is the link to it.....
using A grainger valve
313tiger
