Tune ???
ridered74
That appears to be a 3 bar map sensor, so it's probably either one of two things. They sent you a two bar tune, or you are switching the wrong sensor. The correct sensor is the one that is underneath the engine cover.
If you are impatient like me, and you changed the correct sensor, you could load the tune again but leave your original map sensor in. If it is indeed a 2 bar tune, it should run fine with original map sensor.
StealBlueSho
NA
I will say I am working with another SHO owner in my next of the woods after a bad experience with LMS... and the Made in China 3BAR he received from LMS was defective....
That would make 2 3BAR maps I know of that showed up DOA or died shortly after receiving since ford has out sourced them to China...
This would be number 3 if that’s the case...
mattr66
Show us a pic of the sensor mounted on the intake.
Sent from my Moto Z (2) using Tapatalk
