Did this in August -- unsuccessfully.
1st FWD transmission I had ever removed -- or worked on at all for that matter.
I have a one car garage w/o much room on any side.
Getting it high enough is a problem. I was told I needed 30" or so under the radiator support to roll it out the front. I think I stopped at about 27" and seemed to have plenty of room. I had 2 jack stands, ramps, a pair of bottle jacks. I also used some concrete blocks and several pieces of 2x12 lumber cut in to 12" pieces.
I also bought an engine support bar and transmission jack at harbor freight.
I worked a couple hours on Thursday evening doing the disassembly on the top side -- battery, tray, linkages etc
Another 2-3 hrs on Friday spent mainly getting it off the ground. I think I did some basic front end disassembly as well.
Sat I worked from about 8a to 1a and had a helper from ~10a-1a who had pulled the trans from his accord a few months earlier -- very good help.
The trans was out not long after lunch that day. To that point I didn't think it was too bad of a job, but that was when the head-banging against the wall started.
I had a lot of trouble getting it reassembled. There is a very specific reinstallation process that has to be followed -- nobody informed me of this when I was researching the job, and I didn't recall much in the way of reassembly instructions other than "opposite of disassembly".
I must have spent 8-10 hrs trying to shove, twist, squeeze, push, pull etc the trans into the correct position. It wasn't fun.
I fumbled around w/it all day Sunday -- I think it was that evening when I finally discovered the proper technique, and it started to fall into place. I finally got it all back together Monday afternoon.
During all the fumbling/twisting/forcing I must have dislodged the main trans seal, but din't know it until it was too late. I drove it about 50 miles on Tuesday. It got me to work, but on my way home it blew multiple qts of trans fluid all over the hwy.
At that point I had the pleasure of towing it to a shop and dropping about $1g on top of the 30 (or whatever) hours I had just spent trying to save that $1000. It was a wonderful feeling.
Now that some time has passed I think I would probably give it another try if I had to -- knowing of course, of the care that needs to be taken on reassembly.
Could have finished early on day 4 (successfully) if I had understood reassembly .
