redwraith94
I purchased all of the bearings, and seals to rebuild the trans off of rockauto. So far everything fits perfect, but the output shaft.
Both bearing races on the output shaft have lm48510-n stamped on them. Rockauto sent me two Timken set30 bearings for the output shaft, but the set30's are about 2 1/4 inches in diameter. The bearings from the output shaft are over 2 1/2.
I looked on shonutperformance, and he has listed the Timken set30's as well.
I feel like I have to be missing something obvious here, but I have checked, and rechecked all the other bearings (they fit perfectly) the set30's don't seem to fit anything in the trans at all.
Where can I buy the output shaft bearings?
