Entropy
Hates Pinch Bolts
Refresher:
http://www.v8sho.com/SHO/High_Idle.html
http://www.v8sho.com/SHO/TSB00-3-5.html
http://www.v8sho.com/SHO/highidle.html
http://www.v8sho.com/SHO/TSB99SHOTPS.htm
What I am interested in learning:
1.) Have any of you folks seen any instances where the service kit 'failed' and the same symptoms came back (likely to have to replace the harness again)?
2.) As a corollary, when driving down the road at speed and manually shifting to Neutral, does Ford have logic built in to keep erpm bumped up a bit for a brief bit of time or until certain conditions are met? Maybe a better way of asking this is how quickly does erpm return to idle or near idle when shifting to neutral at road speed?
History:
This on is a 99'. Weather has become much cooler in the past couple of mornings. No codes. Thousands and thousands of miles ago, I replaced the TPS harness when this behavior began - instant fix with no known reoccurrence of the problem until yesterday. Exact same behavior just began again (high idle, erratic cruise speed, varying idle, passing traffic with no throttle input, etc). If the harness was still a $15 part, it would already be on order but it is now over $90 and that is a bit to salty to just 'try' without a proper checkup. I swapped in another TPS I had laying around, disconnected the battery, headlamp drain of memory, and tried again. It seemed to behave much better this morning (actually slowed down when lifting off the throttle) but seemed to still idle a bit high and 'hang' at engine speed before coming down. Sure enough, I backed into a spot at work, shifted to neutral, and she bumped right up to 2500 erpm (give or take) and just hung there. I shifted to Neutral a few times (5-10) on the way in when traffic cleared and noticed that engine speed would hang for a few seconds before coming down.
Any help would be greatly appreciated !
History:
