Roy
The lower timing gear (the one on the crank) was making noise because the slot for the key had worn almost twice as wide. The key also wore down to match. This set of circumstances caused the timing to be ******** by approximately 10 deg. so it was really doggy.
Has anyone else ever seen this same failure of the timing gear?
If I can figure out how to post a picture of the gear I will.
