Timing Belt Tensioner
djcannon
Ohio
TYSHO said:
I wouldn't make a post if I wasn't sure about the part number. I have the box in my back room from the one I installed for the timing belt.
The reason I asked if you were sure was because, if you type in the part # you gave into the below website:
http://www.trademotion.com/partlocator/index.cfm?siteid=214120
It comes up as "Tensioner - Timing Cha" ...which makes it sound like the timing chain tensioners.
So I wasn't saying you were wrong. I was just asking you to double-check. Like they say when working with wood: Measure twice, cut once.
As it turns out, your part # was accurate, but there are more than enough example if incorrect part #'s on this forum, so it never hurts to ask somebody to verify something.
SHOgirl20
Kentucky
Kean_SHO said:
If your still looking, check with Doug at FPS. I got mine a few months ago (for an MTX though)... he had quite a few brand new.
Advance Auto Parts & Auto Zone have one for MTX
groove83
PimpTempoOwner
Kalamazoo, MI
Anyone try buying that one on that site. cause I would like to replace the one on my car before I put it into the car. also like to replace the idlers, but I can only find the one.
SHOgirl20
Kentucky
ford uses 5 different names for one part lol
SHOgirl20
Kentucky
thats the same problem I had
but couple of weeks ago I tried to locate both parts again and I could not find any dealers to have either one
i used mine off of 95 and if it goes bad i'm screwed :D
ScottyDsntKno
NJ
For the 3.2 the TIMING BELT tensioner is hydraulic and located on the left side of the engine if you are looking at it from the front. There is another tensioner on the right side but it is just a stationary pulley that doesn't move, the hydraulic tensioner provides all the pressure. How come you can't re-use the hydraulic tensioner you have?
groove83
PimpTempoOwner
Kalamazoo, MI
I probably can, but the engine bay the 3.2L is going into, is to small to do any work in, so I don't want to get everything hooked up and the car driving...then have something go out and have to pull the motor over a idler pulley or a CPS.
SHORANGERBIRD
Restorer of SHO
Alexandria, Alabama
ScottyDsntKno said:
For the 3.2 the TIMING BELT tensioner is hydraulic There is another tensioner on the right side but it is just a stationary pulley that doesn't move, the hydraulic tensioner provides all the pressure. How come you can't re-use the hydraulic tensioner you have?
Just to verify you, these 3.2 tensioners are NOT hydraulic, it is spring loaded, and there is only one. the round things are called idler pulleys, not tensioners.
ScottyDsntKno
NJ
Are you sure? Just because there are no oil lines going to it doesn't mean it isn't hydraulic. Look at how shocks work.
SHORANGERBIRD
Restorer of SHO
Alexandria, Alabama
-not sure, positive. if you ever saw one apart, you'd see. FPS douglasville, ga. give dougie a call. he'll put you on the straight and narrow....
SHOtimer
#2910
Santa Clarita, Ca
So, how would you explain that when they get old they leak out a black oily substance, and when they stop leaking it they don't work anymore?
...I thought it has been common understanding that they are a self-contained hydrolic- spring loaded unit.
Doug
SHORANGERBIRD
Restorer of SHO
Alexandria, Alabama
SHOtimer said:
So, how would you explain that when they get old they leak out a black oily substance, and when they stop leaking it they don't work anymore?Doug
your experience, dont know, my experience, one would belive that the actuator(the part that pushes the idler) would be oiled for movement, because they will rust and freeze up. no worky, brokey springy.
ScottyDsntKno
NJ
Was bored at school and did a bit more digging.
According to Doug Lewis from FPS,
The ATX cars have hydrolicly dampened, spring loaded tensioner.
So there we have it.
