ticking from engine, not rod bearings.
rcsavage
Florida
that didnt work and now i have no head left on it at all. im out of ideas of how to get this nut off. chissel?
rcsavage
Florida
i figured that much but i mean, is it the same thing as an easy-out with a different name? this is a stripped nut not a bolt. just reminding you.
URLACHER54
Gambrills, Maryland
for fun check the a/c compressor when mine went bad i thought it was my engine it stated to sound like a jack hammer, got it hom and the next day went out and fired it up and it was a bad compessor
AREA 91
PA SHO SHOP
Area 91
When you get all of your oil pan bolts out, don't forget to rotate the pass side CV shaft so you have room to lower the pan. The inner CV joint and corner of the oil pan make for a tight fit. Turn the shaft, and WALA! The pan comes down.
I don't know if this was mentioned, but here's a good guide for ya.
www.shophoenixproject.com
:lol:
rcsavage
Florida
lol thanks for the link. i used that the first time i took it apart but now i know how to do it. and its not the ac compressor, its less than a year old and it not coming from any of the accessories.
