this tranny issue has got me WTF!
SHOBOYV1
missouri
93 TAURUS SHO.TRANNY bucks back and forth with any acceleration if plugged in to the ecm.if unplugged i candrive it in first second and reverse.has this happened toanyone else .i dont think that it matters that its a SHO but if anyone has a taurus that has done this please help.or anyone with the knwledge of what it might be would be great.thnx guyz
jmpSHO
Massachusetts
Definately a bad VSS. If you can drop the y pipe it is actually a simple job to replace.
SHOBOYV1
missouri
thanks to everyone that chimed in.it seems to be unanimous:).i will post results tmrw
SHOBOYV1
missouri
well the weather kept me from getting under the car today but im real excited to see if the speed sensor fixes the problem.hopefully the weather breaks tmrw and i can get out and get this done.
SHOBOYV1
missouri
istill would appreciate any other advice concerning the ymptoms that i described.istill have not been able to find anyone that has expeirieced this exact problem but i know that i cant be the only one that this has happened to.
rick-ng
Rickybobby
Dallas
if the speed sensor isnt the problem then check the wiring loom at the back of the motor as they tend to rub the wires until the wiring shorts out when the motor moves during acceleration....can make a computer go bad as well1
SHOBOYV1
missouri
5/speeds rule
i have to agree.i have had two 5/speeds and that is one thing i never worried about and that was the tranny.also my 5/speeds were 92 so i didnt have to worry about the egr woes either.oh those were the days:)
SHOBOYV1
missouri
thank you rick-ng.i am hoping for the vss to fix it but i definatly will check the wire loom.good looking out:)
lowc
aka vapah lock
Quincy, massachusettes
im actualy in the midle of atx mtx swap and boy its fun
jmpSHO
Massachusetts
thanx jmp-SHO.i knew i couldnt be the only one.
I hope you're not still driving it because those hard shifts will **** and ATX transmission like I did and I am in the process of gathering parts to do an MTX swap.
Change out that VSS asap, I replaced mine like 5 times and I can do it in about 10 mins after the exhaust is down.
SHOBOYV1
missouri
i am going to replace the vss asap.i have to take it to a frineds house to use his jack.
tinkerkathleen
