This is my final analysis - am I right? (Long please read)
DJ SHO
NY
projectSHO89:
Now that you have verifid that your fuel system is working properly..
Check your timing.
Unplug the SPOUT plug near the cam sensor.
Connect the timing light to #1 or #5 (I use #5 since it's easier. Start engine and verify that base timing is 10 D BTDC.
If your timing jumped, it would also explain your symptoms.
Steve
Thanks, but I guess sometimes people don't really read the topics before posting an answer :rolleyes: . IF you read anything that's going on here, THE CAR WON'T START. I can't check the timing with a light. And besides, I've already verified that the timing is fine.
projectSHO89
SHOless In St L
1. I did read your posts and took them into consideration.
2. Yes, you can check timing while cranking, even if the engine won't run.
3. Posts I make before 8:00 AM are often without the influence of enough coffee. Take them for what you paid for them.
DJ SHO
NY
projectSHO89:
Sorry man. You said while the engine was "running". That's ok. I know how things can be in the morning. :)
