Tachometer issues
tompumped
VT
I just bought a cluster to take the tach out of it. I replaced mine and for 150 miles it worked fine. Now once again it's stuck at a given rpm, but sometimes it will read the rpm.
When I got the car the tach was off, it would indicate that the car was redlining at 8k so I took the tach out of a cluster I had. That tach lasted 15 thousand miles. Now i'm back to square one.
Even when I shut the car off the tach doesn't drop down to zero. I'm thinking whatever the issue I just burned out another tach.
I don't think I can read the tach signal with a voltmeter but i'm going to research. I guess i'll start by checking continuity for the wires feeding the tach over the weekend hopefully and report back. I don't know what could be causing this issue, and maybe I threw out two good tachs. I guess too much resistance in the wiring could cause them to go bad.
are you having any other gauge issues? or only with the tach?
because a bad ground can cause all kinds of issues... but would affect other gauges too.
you will need a scope or some other type of device that can read frequency of a signal to be able to look at the signal you are getting to the tach.
tompumped
VT
Only the tach is acting up. I figured id need a scope. Im going to check all the wires for continuity and I guess resistance. Im not sure what values I should expect to see for resistance.
I was going to buy a scope eventually. Its a good thing to have.
AREA 91
PA SHO SHOP
Area 91
I have seen the tach read higher then it should on a couple of different SHO's. This happened when the throttle stuck and the needle was bouncing off the peg.
I have also seen the needle on the other side of the tach before.
tompumped
VT
Two out of the three clusters I have didn't have pegs on the high side of the gauge, but the one I just bought did. I removed it to fit the reverse glow gauge face. I know the gauge face wasn't interfering before i'm going to have to make sure it's not now.
I'll post back after I check it out. I don't have any tools right now.
Anonymous
Philadelphia,PA
mines did the samething in my 91 ,the rpm tach was underneath the peg then eventually somehow went back to normal
tompumped
VT
The needle was bent I forgot to update the thread. I probably bent it installing the gauge faces. Im betting the one I replaced was good but when I got the car the issue was different. This time the needle would get stuck and if I smacked the dash it would fall.
I bent it down towards the floor and it works fine.
Anonymous
Philadelphia,PA
now Im having a big issue with the tachometer in my 95 ATX , my rpm tach is not working nor the gas gauge and the temp only thing working is the speedometer
